Originally posted by doug sinclair:
Michael,
Well then! From what you have said, perhaps the vibrator WOULD be a good place to start. I am not familiar with these Chinese clocks.
Actually, as I suggested earlier, IMO the clock isn't worth the hassles of professional services for the platform and neither is it worth the price of a hairspring vibrator.
I was trying to inform readers that such a clock may require the facilities and knowledge that a watchmaker or watchrepair person would have. If you are this person then great. If you are not, then you may not be able to fix the clock or indeed you may not want to.
These Chinese clocks are for the uninformed, the impulse buyer or the curious buyer. They are not serious timepieces. For me, who owns 2 of them, identical non-working ones - one actually sent to me as a replacement, they are purely educational and items that if I mangle, would not be of any consequence to me.
Back to Dr. Craig's clock - Doug, I would like your expert opinion here.
Is it reasonable to determine if the index has any bearing on the problem by swinging it to the F or FAST side to see if it has an effect on the speed? If it does make the clock run even faster then perhaps an index adjustment can correct the speed problem. If the index position has minimal impact then the balance. in its current state, is not likely to correct the clock's problem. The hairspring may be way too short or completely of the wrong type for the balance.
OTOH, if the index position does significantly alter the speed of the clock and there is an extra length of hairspring sticking out from the end of the stud, is it possible or a good idea to position that forward, in essence slightly lengthening the coil at the end of the hairspring? I believe this is what hairspring vibrator technicians do when calibrating balances to vibrate slower.
Michael
