Most visitors online was 1990 , on 7 Feb 2022
im going to just replace the suspension parts. As for the battery clock, its all parts...lol. By the way, seeing as how ive actually not looked under it, how do i level the clock. The other 400 day i have has adjusters on the base. the 2 clocks only cost me 10 bucks, and the domes are worth that.Nice to see the diamond dials as they're a bit different. It's a Kundo from probably the 1950s/1960s. Looks like the lower part of the spring guard is missing.
Kurt
Hardware stores carry wood shim stock, very handy.I suppose if you had access to a wood working shop, you could make up some nice wood wedges.
yeah getting it level wont be a problem, i just wasnt sure if there was any somewhere easy to see. My other one has the adjusters, and i hadne even looked at this one. I seen what it was and bought it on the spot.Probably could use a couple of levels like item 11703 on the Timesavers website. I bought a couple at a mart a number of years ago. Using two of them, you can get a better sense of fore-aft and side-side level. Of course, having a guide cup properly located also helps.
Kurt
yeah once i looked at it there was no sign of any or a place to put them. Im not worried, getting things level is the easy part.Sometimes the adjuster feet were removed or are missing. Have you confirmed they were never there?
Kurt
