Can't get the movement out
lwalper
Mar 15, 2022
71
19
I decided to start working on a Schatz ships clock and can't see how to get the movement out of the case. I removed two screws from the back, removed the face and was wondering about the screws on the front. Are they holding the plates together or can a couple of them be safely removed?
16,529
2,620
Go after those 3 shiny flat head screws (last photo) and see what happens. :)
lwalper
Mar 15, 2022
71
19
Got it out, thanks. I had taken out the two directly opposite on the back, but left the three that looked like they held the gong. There were actually only two holding the gong, so got the last one holding the back and out it came. I did get courageous and take out those on top, but they seem to only hold that circular cover plate which doesn't seem to actually interact with anything. This clock may not have been used much. The pivots do have a little more than "new" movement, but no clock stoppers. The curious one is the winding arbor on the strike train. Looks like someone tried to close up the wear slot with epoxy. That'll get a bushing if I can figure how to get the hole in the right place. Looks like I need to add a preacher to the toolbox.
16,529
2,620
That's going to be dicey ...
It may be a good idea to wait for someone who might have delt with this particular problem before.
I would probably look for another like donor movement. IMOE, Schatz ship clocks don't often run past about 20 years and have erratic timekeeping. :(
Good luck, Willie X
16,529
2,620
Good luck, Willie X
lwalper
Mar 15, 2022
71
19
Donor clock? Good idea! I'll look around. The clock does seem to run OK even like it is.
lwalper
Mar 15, 2022
71
19
I decided it would just be easier to make a new plate than hunt around for a donor clock. Since I wasn't trying to cut every penny for saving production costs, I added a little more material on that bottom edge and put a bushing in. The plates are only 1mm and there was a bit more arbor to support so so the added bearing surface should improve the wearability of the part. The clock also needed a bushing in the time train. Those little L59 bushings are a challenge to hang on to.
lwalper
Mar 15, 2022
71
19
I thought some before and after shots would be good. I suppose it's an 18000 bph movement. It's currently running at 17952. It need some watching.
20220623_184837.jpg 20220623_184817.jpg 20220623_184803.jpg 20220527_215013.jpg
Reactions: RJSoftware
174,337
1,523,242
52,166
VTC Duane
1,063
2,970
Last page
