"Cannon Pinion" Adjustment on a Cylinder Movement?
Discussion in 'Watch Repair' started by fijidad, Jul 12, 2017.
  1. fijidad
    fijidad Registered User
    Feb 28, 2010
    100
    Escondido, CA
    I've cleaned and repaired a center seconds cylinder movement, but the tension for the hands to keep proper time is incorrect. There is no cannon pinion as in other watches...what is the correct procedure for adjusting this movement so the hands keep up with the rest of the movement? Thanks, Dan
Similar Threads - Cannon Pinion Adjustment Forum Date
Loose cannon pinion Watch Repair Oct 3, 2017
Hamilton 992B vs 4992B Cannon Pinion Watch Repair Sep 18, 2017
1835 English fusee stuck cannon pinion Watch Repair May 20, 2017
Help....need a cannon pinion Watch Repair May 6, 2016
Waltham 1891 Grade 61 CANNON PINION Watch Repair May 5, 2016
