Hello Ron,
Since I don't have a Canada Clock (Hamilton) in my collection (too pricey), I can't answer your question. But,.............. I d0 have the book by Varkaris and Connell that covers these Canadian Clock companies and on page 52 there is a photo of your movement. That caused me to look closer at your picture and I noticed something. In your photos you have the count wheel lever arbor below the "J" hook arbor. What I am calling the "J" hook is the lever that interacts with the pin on the minute arbor that starts the strike sequence. That same arbor has the lifting lever that lifts the count wheel lever somehow, often the count wheel lever directly. In your photos, you have the count wheel lever arbor the BELOW the "J" hook arbor. I believe it should be ABOVE. The two strike arbors have been inter-changed
? Check to see if you have the correct relationship between the "J" and the pin on the minute arbor. That arbor may be in upside down
? I'm thinking your strike lever arbors are, at least, reversed to each other and that radically bent lever going up to the post/pillar should net be bent like that at all.
Sometimes the strike lever arbors are side by side but then the count wheel lever arbor is on the strike side, the "J" hook lever arbor is on the time side.
Jim
