• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
Can This Be Fixed?
bangster
19,895
448
This is a really nice Rhythm Watch Co battery movement; but a clumsy oaf (not me) knocked the clock off the wall, and it messed up the chime.
Two notes are no longer chime-y. They are out of key and harsh and ugly.
I know almost nothing about battery clocks of this complexity, but do you think
the chime notes could somehow be corrected? I don't even know what part
of the clock produces the chime, or how it does it, and the likely answer to my question is No;
but I thought I'd ask. It is a really cool movement, if it could be restored. (I'm thinking
of making a voodoo doll for the clumsy oaf.)
--bangster
RODALCO
Mar 27, 2006
278
60
New Zealand
It is most likely a hairline crack in the circuit board or a solder connection which became dislodged.
There will be some kind of oscillator circuit with an IC and a capacitor to generate the tones.
Try to do a close up inspection and resolder any joints which look suspect.
brc
Aug 30, 2004
61
11
Its a longshot but make sure that the movement or speaker is not loose. I've experienced where the speaker was able to vibrate against whatever it was connected to and make some horrible sounding chimes.
Bruce
bangster
19,895
448
Thanks also.
