Can I use this loop end mainspring without a rivet?
Discussion in 'Clock Repair' started by deena, Jun 9, 2013.
  1. deena
    deena Registered User
    Dec 2, 2000
    447
    Retired from position of Zoning Enforcement Office
    Rural western New York
    I tried a new supplier for 30 hour mainsprings. When I went to use them I see the loop end is not riveted. Can I use it this way?
  2. hookster
    hookster Registered User
    Jan 14, 2011
    1,998
    Pharmaceutical Consultant
    Pottageville Ontario Canada
    Quite a few 30 hour movements had non riveted loop ends. I am a bit concerned, however, about how wide open the loop end is, and would want to re-shape it to be tighter. After doing that, you should be OK, as these springs do not have anywhere near the power of the 8 day ones.
  3. deena
    Dec 2, 2000
    447
    Hookster thanks. I never saw one like this before. I can squeeze it together more once I have it over the post.
  4. hookster
    Jan 14, 2011
    1,998
    Yepp, that is what I would do.
  5. shutterbug
    40,705
    713
    You see that a lot in small clocks. They hold just fine.
  6. Kevin W.
    Kevin W. Registered User
    21,635
    209
    My 30 hour Waterbury has the same thing, just squeezed the loop and its held.
  7. R. Croswell
    R. Croswell Registered User
    9,396
    559
    If you are uneasy about it being this way, you might cut a strip of scrap metal and form a band around the free end and the other part and squeeze the band tight to hold the tail from unwrapping.
  8. hookster
    Jan 14, 2011
    1,998
    Good idea RC, and I have actually seen this done on some 30 hour movements I have serviced.
  9. deena
    Dec 2, 2000
    447
    Thank you everyone. I put them in without incident. So much easier to work with than 8 day springs.
  10. Kevin W.
    21,635
    209
    Is yours in a cottage clock Deena.
  11. deena
    Dec 2, 2000
    447
    Hi Kevin. Mine is an Iron Front. it is not real fancy, but I like it because of the painted design and mother of pearl inlay. It is a smaller clock, but I do not know the maker.
  12. Kevin W.
    21,635
    209
    Nice looking clock Deena.
  13. Phil G4SPZ
    Phil G4SPZ Phil
    Oct 18, 2018
    298
    37
    Retired Chartered Electrical Engineer
    Bewdley, Worcestershire, UK
    #13 Phil G4SPZ, Dec 7, 2019
    I came across this old thread after fitting a new strike spring to a very old Badische Uhrenfabrik cottage clock movement.
    I had been tempted to leave the loop end open, but whilst winding the spring on my Joe Collins-style spring winder, the loop opened up quite alarmingly. So I decided to rivet it.
    This was more straightforward than I’d anticipated. I clamped the loop end together using artery forceps, then centre-punched and drilled a 2.5mm hole through both thicknesses of the spring. I hacksawed a nominal 2mm diameter flat-headed brass rivet down to roughly 2.5mm in length, inserted it from the ‘inside’ and held it in place temporarily using a sliver of masking tape. Then I proceeded to tap the end of the rivet, held against the fixed vice jaw as an anvil, using light blows from a riveting hammer.
    The whole process took less than 15 minutes and the result is strong and looks reasonably neat.
    11AD684A-59CF-46C4-A353-DA16296B451A.jpeg E487B39A-3776-44A6-86DD-F51BB5842AF6.jpeg
    Phil
