Can I remove weights on Cuckoo Clock that control the cuckoo and music?
Discussion in 'General Clock Discussions' started by Renate, Apr 19, 2017.
  1. Renate
    Renate Registered User
    Apr 18, 2017
    I have an old Black Forest cuckoo clock that we just put a new movement in.
    It belonged to my grandparents, and I've never had one before.
    It has no switch on it to turn off the music and cuckoo since it's so old. Can I just remove the weights at night that control those two things so we aren't disturbed and then put them carefully back on in the morning? Or is there another idea?
    Renate
  2. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    That really does not work very well on some of those clocks because the hour hand and the strike count get out of synch. But what you can do is to stop the pendulum at say 8 PM and start it swinging again at 8AM - or whatever time you choose 12 hours later. If you forget and start it later in the morning you can still advance the minute hand, wait for the strike and music at each step and set the proper time. Can you post a picture of the new movement you just put into the clock? Some of the new movements do have a "silent" lever on them. If your new movement has that feature then it might be possible to put a small rod out the bottom of the clock to turn it off and on.
  3. Renate
    Apr 18, 2017
    That was my second idea. Unfortunately, I can't get a pic of the movement (clock is back at the shop since the water wheel isn't turning properly). But originally, the owner of the clock shop said there is no way to switch it off (and that's when we thought he said to either not wind those chains or take off those weights...can't remember exactly what he said.)
    Thank you.
  4. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    There are two basic kinds of movements - "count wheel" and "rack and snail". If it is a count wheel it will get out of synch - but those usually have a wire or little door on the side to get them back in synch manually. If it is rack and snail it will get back in synch pretty much on its own. Ask the shop if it is a rack and snail movement.
  5. Willie X
    Willie X Registered User
    8,136
    32
    While it's in the shop get them to add the little cut-off feature that THT mentioned. If you have a replacement movementit will have this feature, or it can be easily added.
  6. Renate
    Apr 18, 2017
    Okeedok. Thank you!!!!
  7. Renate
    Apr 18, 2017
  8. Willie X
    8,136
    32
    If you push in that little spring loaded shaft, just below the upper right post nut, the cuckoo will be disabled. A small wood stick/block could probably be placed (semi-permanently) between the corner of the whistle and this shaft to stop the cuckoo. This shaft pushes the strike flirt foward and completely clear of the cam that activates it.
    It is easy to install the factory cam that is made for this purpose. It takes 3 or 4 small special parts depending on whether you want the lever through the side of the case, or a wire through the bottom of the case.
  9. shutterbug
    shutterbug Super Moderator
    34,632
    An easy fix was mentioned in the other thread. Stop the clock over night and start it again at the same 'time' in the morning.
Similar Threads - remove weights Cuckoo Forum Date
Why did the clock stop after blocking one of the weights? General Clock Discussions Wednesday at 3:49 AM
How to remove weight cables General Clock Discussions Jan 23, 2013
How to remove Paper Label ? General Clock Discussions Mar 16, 2011
Remove brass numbers General Clock Discussions Sep 19, 2010
How to remove hands from a Smith of England clock General Clock Discussions Mar 7, 2010
