Can enybody tell me why?
Discussion in 'Clock Repair' started by Tom Kloss, May 21, 2019.
  1. Tom Kloss
    Tom Kloss Registered User
    Dec 5, 2003
    1,882
    Retired from one job, started another.
    N.E. Pennsylvania
    This a #20 drill bit I picked up at an auction.
    Can anybody tell me why they would do this to a drill bit?
    Tom
  2. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,374
    79
    Clock service & repair
    Santa Rosa Calif.
    Maybe so it would shear off at the thin point rather deep in the hole they were drilling.
  3. R&A
    R&A Registered User
    Oct 21, 2008
    4,203
    107
    It's so the shank doesn't rub on the ID of the hole when the chips build up,when drilling past the flutes. The flutes aren't long enough for the chips to clear.
  4. Uhralt
    Uhralt Registered User
    4,958
    604
    Sounds reasonable. But wouldn't a more shallow cut be sufficient for that purpose? It would leave the drill stronger.
  5. Willie X
    Willie X Registered User
    12,774
    985
    Well,
    The flutes are there to remove the chips. So, I cant see where removing the flutes would help with chip removal.
    Maybe it was some odd clearance issue, where the bit couldn't be brought into position without the flutes digging into something:???: Willie X
  6. David S
    David S Registered User
    Dec 18, 2011
    7,201
    246
    Brockville, On Canada
    The only thing I can think of is that the reduced shank will clear the chips much better if one is drilling a deep hole and due to limit of the tailstock feed screw, can't back the bit all the way out without unlocking the tail stock.
    I know a stretch.
    David
  7. shutterbug
    43,987
    1,314
    I can't even imagine HOW he did that, let alone why. Maybe he had some special project that 'required' him to hold on to the bit while it was turning.
  8. bchaps
    bchaps Registered User
    Dec 16, 2001
    1,130
    14
    Mountain Top, PA
    But Tom...the real question is why did you buy it.... or when you said you "picked it up"...:???: Bill.
    Call me when you can chat..570.983.5352
  9. R. Croswell
    R. Croswell Registered User
    10,564
    932
    That's what I think also.
  10. bangster
    bangster Moderator
    19,833
    434
    To make it pretty.
  11. R. Croswell
    10,564
    932
    .161 - .080 - .161 well if you are a drill bit, I guess that's pretty you know...... not sure we can use the "s--ey" word here.
