Can Chime Barrel be adjusted once plates are back together? Surely there must be a way?
Probox
Oct 27, 2015
281
Halifax Canada
Hi all. I am working on this triple fusee clock with 8 bells. I cleaned and re-assembled the clock only to learn that the chime is off by a small amount, just wouldn't let that last hammer fall. See pictures. I am wondering, there must be a way to adjust that chime barrel without letting down the power on all three fusees and removing the plates? I don't think with this thick brass I can even use a plate spreader. Please has anyone run into this before? I had marked the correct spot before disassembling but it just moved a tiny bit during reassemblly and I hadn't noticed/checked it before adding power. I'm really hoping there is a secret I don't know about.....don't really want to start all over.
20220126_114944.jpg 20220126_114954.jpg 20220126_115007.jpg 20220126_115038.jpg
16,257
2,480
Look for a setscrew on a hub somewhere, usually it's easy to see and on the gear that drives the pin drum. Willie X
Probox
Oct 27, 2015
281
Halifax Canada
Oh, not seeing a set screw but you gave me an Idea. I'll get back to you.
Had to resort to the plate spreader, which is never ideal. May have got it now though
173,673
1,516,536
51,879
Nauman
1,062
2,969
