Can Chelsea Platforms be Replaced with Generic Ones?
Discussion in 'Clock Repair' started by Uhralt, May 15, 2019.
  1. Uhralt
    Uhralt Registered User
    3,811
    371
    I'm trying to repair a Chelsea ships clock that must have been immersed in water for a prolonged time. Maybe it was found in a sunken ship or it spent some time in a flooded basement. Who knows? The serial number 560918 makes me think it is from the 1950s.
    The case is a black phenolic case. as you see in the first picture, its bottom is filled with a layer of rust. I have already removed most of it but you get the image.
    The movement is shown in the second picture. The back plate screws are completely rusted away. After poking a bit with a toothpick I could insert some temporary screws just to hold the movement together before it gets a bath in Evaporust. The platform escapement is covered in rust, especially the hairspring. I doubt that it will be able to run once the rust has been removed.
    Therefore my question: Can the platform be replaced with a generic one with a similar size, like one from a carriage clock or one that is commercially available now? In other words, did Chelsea use platforms with the "usual" beat number? If this is a case I could put in one of these temporarily and wait until I find an authentic replacement.
  2. bruce linde
    bruce linde Technical Admin
    5,613
    506
    oakland, ca.
    you could also reach out to ron bechler in san jose... he's been the west coast chelsea guy forever and has parts... (408) 926-3212
  3. Dave T
    Dave T Registered User
    Dec 8, 2011
    2,645
    69
    retired accountant
    NC
    There is also a guy here in Florida that I've used.
    Lenny Taube <lenny@clockmedic.com>
  4. Uhralt
    3,811
    371
    Thank you Bruce and Dave! I will give them a try once I confirmed that the platform is beyond reasonable repair. I'm looking forward to seeing the results of the Evaporust treatment. It is the first time I try it.
  5. Dave T
    Dec 8, 2011
    2,645
    69
    retired accountant
    NC
    Post a few progress pictures as you go.
  6. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    555
    Retired, and now full-time clock repairs.
    Winter Park, FL
    I have some of those platforms so, if you are able to resolve everything else and the platform will complete it, let me know.
    Ed O'Brien
    Winter Park, (Orlando area) Florida
  7. Uhralt
    3,811
    371
    Will do. This will be an adventure or a total flop. When I tried to let down the mainspring the barrel pivot that was sitting in the backplate just completely disintegrated into rust dust...….
  8. Uhralt
    3,811
    371
    I will, thank you for the offer. I will see what remains of the clock when the rust is gone. I have never seen steel parts that completely converted to rust like the screws and the barrel pivot in this clock.
  9. bruce linde
    5,613
    506
    oakland, ca.
    i remember reading a post from someone who put a rusty verge in evapo-rust and when he came back to check it it had completely dissolved. :cool:
  10. Uhralt
    3,811
    371
    Well, I guess that can happen to me with some of the parts. I will get the Evaporust tomorrow and will show in a couple of days what I've left after treatment. The disappearance of the barrel pivot, about 5 mm in diameter, was a shock.
  11. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    739
    26
    Retired Military
    Hampton, Georgia
    Uhralt, over the years I have repaired many Chelsea military clocks. All I have done were 18000 BPH. For what its worth!
  12. Uhralt
    3,811
    371
    Thank you, that is helpful!
  13. Uhralt
    3,811
    371
    Now, after a bath in Evaporust over night I have the following results:
    Surprisingly the hairspring of the platform seems to have survived but the upper pivot of the balance wheel is gone. The wheel wobbles. The upper part of the screw that holds the cock is also gone, so I can't unscrew the cock. I believe I will need a new platform.
    Two small wheels are quite damaged. One has lost a pivot completely, the other has a badly eroded arbor but the pivot is still there. Probably it was somewhat protected sitting in the pivot hole with some oil. I'm not sure if I can repair these wheels. They are quite small
    As mentioned before the mainspring arbor has lost one of the pivots completely. I think this can be easily re-pivoted. Surprisingly the spring inside the barrel looks almost pristine. No visible rust.
    Here are the pictures:
  14. Uhralt
    3,811
    371
    Update: I re-pivoted the barrel arbor. See picture: It wasn't easy to find center in this mess but it worked out well.
    Dave T and Kevin W. like this.
  15. Uhralt
    3,811
    371
    Some more progress over the weekend. I repivoted the seconds wheel where rust hat eaten the pivot. I also made a new arbor for the wheel with the badly corroded arbor. I had to drill through the pinion to mount it to the new arbor. In order to hold the pinion a had to "sacrifice" one of my collet by boring it to the fitting size.
    With the two repaired wheels the movement is now complete and working smoothly with the exception of the platform escapement.
    The mainspring turned out to be just a bit dirty but otherwise in very good condition. I cleaned and oiled it.
    During removing of the rust the hands had lost their blueing. I polished and re-blued them by heating. The dial cleaned up considerably using some crème of tartar. It was yellowish-brown stained by all the rust and shows now silvering with some wear. I'm not sure if I should re-silver it, it might come out looking too new, and I'm not sure if the current silvering is actually silver or something else. Any advice what you would do?
    Chelsea9.JPG Chelsea10.JPG Chelsea11.JPG Chelsea12.JPG Chelsea13.JPG Chelsea14.JPG
  16. Uhralt
    3,811
    371
    Hi Ed,
    Thank you for your kind offer. As you can see from my previous post the clock is now in a condition that it would run with a working platform. I will send you a PM to discuss further.
  17. Ravens_Time
    Ravens_Time Registered User
    Nov 26, 2016
    125
    Sumerduck, VA
  18. Uhralt
    3,811
    371
    Thank you! When I first opened the case and saw the mess I had doubts that I could revitalize this clock, but I tried anyway. There wasn't much to loose so I got more brave (=aggressive) in my approach than usual.
    Kevin W. likes this.
  19. shutterbug
    40,680
    707
  20. Dave T
    Dec 8, 2011
    2,645
    69
    retired accountant
    NC
    I'm impressed. Good job, and quick too. As for the dial, I think I'd be inclined to leave it as is. It's perfectly readable with all the graphics still there. Just gives it a little character.
  21. Uhralt
    3,811
    371
    Thank you, that's probably what I will do.
  22. Uhralt
    3,811
    371
    I cleaned up the back plate some more. Compare this with the pictures in the first post! The black discolored areas are now cleaned up. I think that the black stuff, that was extremely hard to remove, was bakelite that had somehow been transferred from the case. One can see in the cleaned case that there is some bakelite surface missing. The black stuff wasn't touched at all by Evaporust, regular ammoniated clock cleaner, or paint stripper (applied in that sequence). I finally got it removed by a combination of 1000 grit sandpaper, 0000 steel wool, and jewelers rouge.
    There are still some areas where a copper color remains. In order to polish this out I would need to remove quite some material because some pitting has been going on. I think I will stop here and consider this as a reminder of the state the clock has been found in.
    BTW, the Philips screws will be replaced by proper blued slotted screws as soon as they arrive.
    Kevin W. and Dave T like this.
  23. Uhralt
    3,811
    371
    Almost done! I suddenly remembered that several years ago I put a Chelsea platform in one of my French clocks that was missing a platform. Now I replaced it with a modern one and transplanted the Chelsea platform into my ships clock. It fits perfectly and runs great!
    Now all that's missing are the four screws for the back plate and that little fork that pushes the regulator of the platform when you turn that small regulating wheel in the dial. I guess it is unlikely that I will find one so I will attempt to make it.
    Here is the clock with running escapement:
    Old Rivers, Kevin W. and Dave T like this.
  24. Kevin W.
    Kevin W. Registered User
    21,629
    209
    Uhralt you have done a really good job on this clock. It looked almost beyond any help. Thanks for showing us the steps you took and all the pictures in the process of restoring it.
  25. Uhralt
    3,811
    371
    Thank you Kevin,
    I appreciate your kind words! I had doubts myself if I could restore this clock but I decided to try anyway. I guess it's true, there is no such thing as "beyond repair". Maybe with exception of the original platform. That was out of my league. But maybe somebody good in watch repair could have restored that as well. It needed an new balance staff and a new hairspring as a minimum. Even though the hairspring didn't rust away, it was "glued" together with only a few free loops moving.
  26. Bill Cann
    Bill Cann Registered User
    Mar 26, 2019
    21
    Nice work!
    BTW, I picked up a replacement regulator fork to repair a Chelsea from Ron Bechler mentioned earlier in thread.
    Bill
  27. Uhralt
    3,811
    371
    Thanks for the tip! That little fork is more complex to make than it looks.
  28. Uhralt
    3,811
    371
    Here is the finished product, on the wall and running. I'm glad that I didn't do too much to the dial other than cleaning and rubbing with cream of tartar. It looks vintage but not shabby.
    Dave T and woodlawndon like this.
  29. shutterbug
    40,680
    707
    Looks good!
