Most visitors online was 1660 , on 12 Dec 2020
It's known as a bolt tool, and is used for flat polishing small items, particularly screws, which are held in one of the slots in the clamp at the bottom of your pictures. The first picture is of the top of the tool with the adjusting screws, and the second is the underside, showing the two levelling screws, and is the side where the screw heads are mounted. In use, the two levelling screws are adjusted so that the screw or other part is level with the flat surface of the oilstone or polishing plate. There are other, more complicated versions of this tool, but they all work the same way to achieve the desirable truly flat polish on the object.It seems to be some sort of jig for polishing or truing up some part or something...it's about 1 1/2" long X1 1/4 " wide and 3/16 " thick
I re-added your photo. Let's see if it works.Hmm some linked photos don't show?
Thanks so much, I guess I was overthinking it. New to this obsession and so far just happy to get everything back together....polishing will come later, maybe!Hi 2manyparts, and welcome to the forum,
I haven't read Daniels, but wouldn't that be tin and not zinc ?gmorse has it spot-on, its a bolt tool. Daniels say used on a zinc plate.
No, it's definitely a zinc plate. You should read it sometime!I haven't read Daniels, but wouldn't that be tin and not zinc ?
Giving the appearance of being shop made, its anyones guess as to what it was made for.It seems to be some sort of jig for polishing or truing up some part or something...it's about 1 1/2" long X1 1/4 " wide and 3/16 " thick
View attachment 634336 View attachment 634337
I venture to suggest that 'almost certainly' should be abbreviated to 'certainly'. I have made and used these for flat polishing, as have generations of watchmakers for as long as watches have been made by hand methods. That other methods have been developed which utilise machinery is equally certain, but this tool's purpose is clear....it was almost certainly for polishing screw heads as suggested by Graham...
GrahamHi Jerry,
Jerry,Giving the appearance of being shop made, its anyones guess as to what it was made for.
Respectfully just guessing here, but think that possibly the third steel "leg" which does not appear to be adjustable is there simply to slow down/prevent the brass body of the jig from being ground away while polishing the screws/bolts...or it was possibly adjusted just a hair proud of the jig surface and then slipping the bolt to be polished down to that same point ...essentially the polishing surface, and then securing it.....Now that I said that I tried un threading it and low and behold it too is slightly adjustable albeit without a locking bolt....there is about one thread left above the body......perhaps it started out significantly longer but was slowly worn away over the years as most of the pressure I assume would have been applied on that side if the jig and it would be slowly simutaneously polished away with the bolt heads. Your best practice tip is no doubt true but I would think you could have all 3 legs on a true and flat polishing surface (avoiding the added variable of trying to keep 2 separate plates/planes parallel) although I guess keeping the leveling legs off the surface explains why they are longer..... anyway the benefit of 3 would be that they are always stable as opposed to 4 which would be continually frustrating to keep in unison so to speak and 2 which would not provide any stability at all....it's what makes tripods so great....occasional redressing of the polishing stone would keep the surface true. Someday I will give it a go on a flat hard Arkansas stone and depending on the results maybe post a pic ! ThanksJerry,
I can categorically say it is not "anyone's guess". First, it is not shop made.
Watchmakers know exactly what it is. It was a very common pattern made early in the 20th century. What it is for is flat polishing. Either screw heads or springs.
For those who do not know (and I was surprised no one asked why a tripod does not work) The work is fixed to the underside of the tool (screws fixed in the clamp head down, springs shellacked or superglued). The two screws are adjusted until the polish strokes are witnessed to be across the full face of the work. Best practice is to keep the adjusting screws off the polishing/grinding surface.
When set up correctly, a flat surface can be repolished very quickly.
As the Swiss say, why invent a new tool when the back of a tweezer will do.
Jerry,
Now that is a new one to me. It is interesting how things come to be named across cultures.They are also called "frogs" Boley still sells them with that in the description.
I remember something about a frog to do with blacksmithing, not the actual frog called "blacksmiths frog".
DeCarle said they were called bolt tools because they were originally made to polish the bolt of "swing movements" huh?
He also calls the pull-out-piece a bolt.
Thank you both! I never took the time to research the derivation, I just used the thing (shame on me).
How do you finish a short screw with a shallow head with the locknuts on that side of the plate?It has locking screws which seem frowned upon by Daniels (he probably thought they wasted time...)
That's what I thought, and I agree that the screws in the edge are a neater idea.You don't! You have to put the locknuts on the other side.
