Can anyone help ID this watch we think it might be a pocket watch
Discussion in 'American Pocket Watches' started by Avro683, Apr 30, 2017.
  1. Avro683
    Avro683 Registered User
    Apr 30, 2017
    Hello folk's, new member here with a request for help. I am assisting in a joint UK Canada and Germany investigation of a WW2 Crash site and this watch was found amongst the wreckage site. We are trying to ID what type of watch it would be. We have been able to find out the maker as being the ID watch Case CO out of New York but we would be interested if anyone can shed light onto the type of watch this is??
    Thanks in advance,
    Avro683
  2. Kevin W.
    Kevin W. Registered User
    20,163
    10
    It was a nice watch one time, with a sterling silver case.
  3. Avro683
    Apr 30, 2017
    Thanks Kevin
  4. gmorse
    gmorse Registered User
    7,191
    22
    Retired from Xerox
    Hi Avro683, and welcome,
    It was certainly a pocket watch, judging by the size.
    Are you sure that the two fragments in your second picture are part of the same watch? The left hand part has the remains of the dial attached to the main plate, which looks more or less flat and circular, whereas the right hand part also appears to be the inside surface of a main plate but very severely distorted. A watch like this would not have had a top plate of such thickness, which makes me wonder if these are the remains of two watches. From the position of some of the holes in the right hand fragment, I'd guess that this was not a full-plate movement, (with two plates extending over the whole watch), but possibly a "bar" type.
    Neither seem to have any steel parts left, and the dial fragment doesn't look like an enamelled one, but possibly melamine or a similar material.
    Incidentally, the case maker would not necessarily have made the movement.
  5. Avro683
    Apr 30, 2017
    Interesting .. thanks Graham
  6. Steven Thornberry
    Jan 15, 2004
    17,809
    20
    FWIW, here is an earlier thread discussing the Id Watch Case Company. There may be others. And this link has a bit on info. relevant to the trademark itself. This won't tell you much about the watch itself, however.
  7. Avro683
    Apr 30, 2017
    Thanks Steven, that thread topic is what brought me to this forum after a google search :)
  8. Whereisitat
    Whereisitat Registered User
    Mar 14, 2017
    46
    There are some clues-
    The minute wheel is huge compared to most. And the arrangement of the jewel holes may be a key. Also a back view of the front plate may help.
    And that went in hard- there are imprints in the case of the winding & mainspring wheels, There is a center plate imprint-this was likely a 3 bridge movement. And there is even a faint outline of the balance cock & wheel. All from impact so it was quick.
  9. Firegriff
    Firegriff Registered User
    Feb 22, 2013
    564
    Was it in an explosion weird things happen it items in a powerful explosion and the resulting heat and fire or possibility of a aircraft impact/fire would be interesting to know.
  10. Firegriff
    Feb 22, 2013
    564
    Sorry, I did not have enough coffee yet and was looking at the pictures more than the text so I answered my own question.
  11. Avro683
    Apr 30, 2017
    Not sure about it being two seperate watches.. the chap that found it said they are from the same one:???:
  12. gmorse
    7,191
    22
    Retired from Xerox
    Hi Avro683,
    Are you able to post a picture of the other sides of those two fragments, please?
  13. Whereisitat
    Mar 14, 2017
    46
    Missed it-I thought it was a front / back piece from the same watch or movement. Second pic showing 2 objects-your saying it is the same piece displayed front / back in the same photo?.
    And I also should have said hour wheel is very large compared to others I have seen-but I'm new(ish).
    It was a 3 bridge movement & the shape of the center plate is clearly imprinted on the watch case back (silver) in the 1st photo.
    So-
    A 3 bridge movement-with a relatively large hour wheel-does that narrow it down?
  14. Avro683
    Apr 30, 2017
    Hello Graham, the pieces are in storage and unaccessible for further photos sadly.
  15. Firegriff
    Feb 22, 2013
    564
    To bad it would be a fun hunt to ID this watch.
  16. Avro683
    Apr 30, 2017
    thanks
    I wish we could id it for sure.. I trawled alot of photos online but nothing that looks like it.
  17. richiec
    richiec Registered User
    Feb 24, 2007
    5,467
    automotive warranty inspector
    Brick, Ocean, NJ
    Re: thanks
    id what?
  18. Kevin W.
    20,163
    10
    Re: thanks
    Richie he posted a while back about a watch that was in a airplane crash.
  19. Bard
    Bard Registered User
    Nov 18, 2016
    32
    Re: thanks
    Dial is double sunk.. looks like rose or red minute index ring.
    I'm not so informed, can't help much.. will continue image searches :D
  20. Avro683
    Apr 30, 2017
    Re: thanks
    Thanks guy's.. what we do know is this is not Military issue by the RAF
Similar Threads - anyone help watch Forum Date
Waltham Pocket watch 1857 model made in 1862 Can anyone help with more info please American Pocket Watches Jan 29, 2013
Can anyone help identify this English watch? American Pocket Watches Jan 21, 2005
Pocket Watch D A Reesor can anyone help American Pocket Watches Oct 6, 2003
