can a floating balance like in a hermle 340-020 be rebuilt?
BCR
May 3, 2020
I don't have the broken clock in hand yet, so no pictures. It has a FLOATING BALANCE similar to one like the ones in a Hermle 340-020 movement, only somewhat smaller and no longer available. It's for a small WUBA Warmink 8 day twin bell movement. I should probably wait until I have the clock so I can take tons of close-up pictures, and yes, I will happily do that when and if I finally get the clock. But, for now, does anyone know of an article or :???: talking about how to repair/rebuild a floating balance in general? Thank you
46,395
1,851
Yes. David LaBounty has a DVD on how to do it. Go to the clock class page and scroll down.
wow
Jun 24, 2008
5,046
500
75
Pineville, La. (central La.)
BCR, most of the floating balance movements I have worked on do not need the balance rebuilt unless someone has actually broken it. In most cases they just need a good cleaning. The problem in almost all of these movements is usually a power problem in the time train. Once bushings are installed where needed and pivots polished, the balance performs well. I almost always bush C2, T2, and S2 and several others. The barrels and caps are often worn badly and need bushings. Once you clean the balance, mount it in a vice and rotate the balance wheel. If it continues for a couple of minutes, it’s fine.
13,739
1,415
About all you can do is: straighten the frame, replace the wire that goes through the balance and repair or replace the spring. Balance springs are somewhat generic but AFAIK only available from a donar clocks.
So, it will be a long shot ...
165,376
1,439,394
86,181
Kevsun
2,873
