American California has discontinue selling denature alcohol,
Discussion in 'General Clock Discussions' started by pwedel, Feb 13, 2020.
  1. pwedel
    pwedel Registered User
    Jun 26, 2009
    19
    A question was brought up at out last chapter meeting, California has discontinue selling denature alcohol, many use it as their final rinse to remove water after they clean their, and rinse the clock movement in hot water. There are other rinse products available thru the clock supply sites; but, is there any other product that can be used in place of denature alcohol?
  2. Kevin W.
    Kevin W. Registered User
    22,016
    268
    What about isopropyl alcohol the higher alcohol content like 80 to 90 percent. Most people i know use this.
  3. pwedel
    Jun 26, 2009
    19
    Thank you Kevin
    Kevin W. likes this.
  4. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,439
    154
    Carson City, Nevada
    Denatured alcohol, also called methylated spirit or denatured rectified spirit, is ethanol that has additives to make it poisonous, bad-tasting, foul-smelling, or nauseating to discourage recreational consumption. It is sometimes dyed so that it can be identified visually.
    Isopropyl is preferred due to the additives. I can usually find a quart for a dollar at Dollar General. I don't think it goes bad if kept sealed
  5. JTD
    JTD Registered User
    Sep 27, 2005
    7,004
    395
    I agree with all above, I have always used isopropyl alcohol. Denatured spirit has the additives to make it unpleasant and these often leave a whitish residue.
    JTD
  6. pwedel
    Jun 26, 2009
    19
    Thank you
  7. Willie X
    Willie X Registered User
    12,488
    864
    Not to mention the blindness and lingering death ...
    91% Isopropyl alcohol is available at your closest Wally-World. It's usually about 2.50 per quart.
  8. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    758
    194
    Texas
    Regular rubbing alcohol is 50 - 70% Isopropyl Alcohol so it already contains water. Willie is right, that sold at Big Box DIY stores, Walmart , and paint suppliers will be 91-99%.
    My biggest question is the loss of denatured alcohol for use in mixing and thinning shellac. Ethanol is the solvent of choice for shellac preparation. Denatured alcohol is ethanol with methanol and Methyl Isobutyl Ketone added to make it unfit to drink. I guess you could go to the local liquor store and buy "Everclear". That's ethanol. Just don't use the "2 ounces for the shellac one ounce for the maker" formula and you should be alright. :D
    Ethanol is a grain based product. Isopropyl Alcohol is made from petroleum or natural gas. If you try to mix shellac flakes with Isopropyl Alcohol it must be 99% or the water will ruin your shellac.
    DPC
    Bruce Alexander and THTanner like this.
  9. bangster
    bangster Moderator
    19,520
    366
    Yeah, but what's with California??
  10. shutterbug
    41,816
    927
    They can't get rid of the smog, so they get rid of everything else :D
  11. claussclocks
    Mar 14, 2013
    758
    194
    Texas
    It's a fact that cows produce methane gas. Soon they will outlaw beef and raising cows to cut air pollution and then go buy bigger cars.
  12. Levi Hutchins
    Levi Hutchins Registered User
    Oct 21, 2012
    86
    13
    Soon, "they" will be banning lead paint for clock cabinets and radium for dials!
    O^8
  13. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,442
    95
    Devon
    California seems to like banning stuff, they even banned vaping but not smoking which kinda makes you think the plot is well and truly lost.
  14. Willie X
    12,488
    864
    You do visit other states ... right?
  15. Uhralt
    Uhralt Registered User
    4,346
    467
    Just wondering if E85 gasoline would work well. It should be available in California and is cheap. It has 85% of ethanol.
  16. lylepete
    lylepete Registered User
    Feb 9, 2003
    226
    E85 technically it would work but it has gas in it and would stink. Just buy some good old everclear.
  17. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,592
    53
    Frys.com shows that they still carry 99.9% Isopropyl in California.
  18. shutterbug
    41,816
    927
    The only reason gas is added to E-85 is to keep people from drinking it. Otherwise, it is everclear.
  19. Willie X
    12,488
    864
    I think Bugs has a work around there. 15% gasoline probably won't make much difference making your shellac. Or just buy it already cut. A good paint store can supply you with many different types. Willie X
  20. claussclocks
    Mar 14, 2013
    758
    194
    Texas
    Well, for now, here in Texas we have the real thing. In fact, since I have business with Chemical distributors here I can get from 5 gallons up to a 330 gallon tote with a phone order. However, I don't know what I would do with 330 gallons of the stuff. I do keep a 5 gallon pail around for shellac making and repair. Since lunacy in government seem to start on one coast or the other and move inland I assume someday we will face the same issue.
    DPC
  21. steamer471
    steamer471 Registered User
    Nov 2, 2013
    437
    76
    Self employed
    Charlotte NC
  22. claussclocks
    Mar 14, 2013
    758
    194
    Texas
    #22 claussclocks, Feb 17, 2020
    It has nothing to do with clocks but "Everclear" is used in veterinary medicine as an antidote to antifreeze poisoning. There are, of course, certain dosages but given within thirty minutes of antifreeze ingestion by an animal it can prevent kidney failure by binding up the ethylene glycol before it attaches to and destroys the kidney cells.
    Just a bit of trivia
    This just highlights the question as to why outlaw denatured alcohol. You can't drink it. The methanol used in denaturing it is poisonous and so is the MIBK. The product cannot be separated without a very complex distilling process. Hardly worth the effort. Maybe I can see banning Everclear. Improperly used it is dangerous. But denatured alcohol is a solvent used in paint, printing, and other industries.
    The cosmetic industry uses another product SD40 Alcohol which is drinkable but is very strictly controlled
    DPC
  23. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,523
    99
    retired educator
    Greenfield, Nova Scotia
    Not sure it is a great idea to use any flammable liquid for clock repair.
    Ron
