Most visitors online was 1990 , on 7 Feb 2022
Many thanks,I'll see if I can find one using those details,many thanks danTry one of the mainplate showing if there are any numbers stamped under the balance.
If I may take a guess you have a 27 lingues caliber 98 watch.
Thankyou very much for all your advice,I'll keep looking,so far I've found no reference to any info on this movement,must be a little rare,it is a big pocket watch though.You often find the caliber stamped under the balance on Omega movements. Too bad it was not the case here.
I don't know where one would find a balance for this watch. Possibly it can be re-pivoted. There is ofcourse also the possibility to cut a new balance.
Be careful with the old broken balance. The measurements can come in handy. Instead of cutting a new staff from scratch one can look for a replacement with one or a couple of dimmensions to adjust.
Good luck.
