Calculating the Size of a Mainspring
Discussion in 'Hints & How-to's' started by bangster, Apr 4, 2015.
  1. bangster
    bangster Super Moderator
    16,302
    20
    #1 bangster, Apr 4, 2015
    LABOUNTY'S MAINSPRING FORMULA
    The formula I use is:
    L = .3927 [(D*D) - (d*d)]/T
    Where:
    L = length in inches
    D = inside diameter of the barrel or space available for the mainspring to unwind, in inches
    d = diameter of the arbor in inches
    T = thickness of the mainspring in inches (not the width!)
    (D*D) = D squared
    With this formula you can vary the thickness of the mainspring a little (plus or minus 0.002" but favor the thinner side) and maybe find a suitable replacement.
    —David LaBounty
    For open springs, let D =the diameter of the mainspring wheel. The width will be determined by the depth of the barrel or the available amount of winding arbor. —bangster
Similar Threads - Calculating Size Mainspring Forum Date
Mainspring, measuring length of Hints & How-to's Sep 16, 2013
Mainspring, Re-holing Hints & How-to's Sep 8, 2013
Mainspring, Installing a "C" restraint Hints & How-to's Aug 21, 2012
Mainspring Chart Hints & How-to's Oct 26, 2010
