I have a Gents C7, which has been running nicely for a few years now.
Accuracy is controlled by a Satellite time device, which usually controls it to less than a second, compared to Satellite Time Signal. This loads a ball-bearing off and on to a carrier about halfway up the pendulum shaft.
However, every Spring and Autumn it runs out of range, and then I have to adjust the knob at the bottom of the pendulum, on which the bobweight sits.
It is obviously a compensated pendulum, by the design, but it is overcompensated, i.e. it runs slower in winter than in summer.
Only two things appear to me to be relevant;
(a) the suspension spring was broken, and I replaced it with an 0.015 feeler gauge.
From what I read, no-one seems to think this important.
(b) This clock worked fine with its first owners (SABC), but it lived underground in a more-or-less constant temperature environment. I don't have that option, and the temperature in my lounge ranges from 5C to 30C ( 28.3C as I type!)
Should a professional clock be able to handle this range?
Has anyone else had experience of wide temperature variations?
Paul Galpin
Paul Galpin
