I just acquired a very pretty 18k foudroyante seconde mort hunter, signed on the cuvette C.J. & A Perrenoud & Cie., Le Locle, No. 34,783. The movement itself isn't signed nor does it have an easily visible serial number. I bought this watch because I believe it was made by Louis Audemars. I haven't found a photo of an identical Audemars movement, but Zantke shows many dials that look essentially identical. For that reason, because the movement has two tandem-wound mainsprings with internal ratchets, Louis Audemars-like bridges, and appears to have a shepherd's crook counterpoise, I attribute the watch to Louis Audemars. On the other hand, I have a signed Louis Audemars foudroyante seconde mort that differs from the Perrenoud in (a) not having a subseconds dial, (b) have a gilt movement, rather than a nickel one, (c) having a helical hairspring, rather than a flat or Breguet one, (d) needing to be wound in one direction for one mainspring and the other direction for the other mainspring, rather than in one way for both, and (e) being pin-set, instead of lever-set.
Here are photos of the Perrenoud.
Here are photos of my signed Louis Audemars foudroyante/seconde mort.
I would appreciate your views as to this watch, C.J. & A Perrenoud, and my attribution of it to Louis Audemars.
