bw raymond center pinion question
Luca
Jan 19, 2004
873
12
I went to let down the mainspring of a BW Raymond - had a bench key in winding slot to slowly let it off and pegwood at the click. Instead the center pinion unscrewed. Is this normal? Is the pinion still usable - can I just screw it back on?
Sorry for such a basic question - I haven't done anything with this type before.
Luca
EmmaR
Jun 29, 2007
518
7
www.taswatchhospital.com
just screw it back on.. it's a healthy thread anyway!.. this is called a safety pinion, it is to stop escapement damage if there is a mainspring or click failure. dont put loctite or anything on it, it wont unwind in normal operation. maybe the mainspring has skipped its pin in the barrel or something to cause this, unless you let go of the ratchet wheel when letting it down. make sure you screw it back on the right way up, and let us know how you go!
*EMMA*
Smudgy
May 20, 2003
2,874
25
Just to expand, just snug it down, but don't tighten it too much. Don't worry about it being too loose, the pressure from the mainspring will tighten it as much as it needs to if it's a little loose. Also make sure that the flat part of the hole in the wheel aligns with the flat spot on the staff and seats properly when the gear is screwed on. If you tighten the gear too much, the next time the mainspring slips or breaks you will be replacing jewels and/or the balance staff.
EmmaR
Jun 29, 2007
518
7
:) just logged on to add this, and someone already has.. :) good stuff.
*EM*
168,720
1,472,009
48,530
knarf0118
2,955
