Most visitors online was 1660 , on 12 Dec 2020
TeaclocksThe pivots look to not be in the center of these bushings.
Where the Bushing holes cut then the bushings installed then the pivot holes where cut using a depth tool?
Thank you
Never worked a movement with these bushings, they look all the same outside diameter.
Thank you.
View attachment 640708 View attachment 640709 View attachment 640710 View attachment 640711
I agree. I've bushed a number of these and never had the "plugs" move. Just imagine they aren't there and locate the bushing on the original center of the pivot hole.Probably best not to " whack" on the old inserts. Willie X
