Bushings and tools
Loren Marcus
Jul 19, 2022
7
61
New clock guy here wanting some advise on bushing assortments and tools needed to put bushings in . I'm mainly working on regula cuckoo clocks also where to buy these.
Thank you
Loren
17,155
3,007
At a minimum you would need a #2 and #3 KWM reamer and about 3 well spaced bushing sizes for each reamer. This will get you started with nearly all modern cuckoos. All bushings would be 1.4mm height. #10, #12, #65 for the #2 reamer and #14, #17 & #20 for the # 3 reamer.
And, of coarse you will need some way to precisely turn the reamers and finish the pivot holes to size.
Reactions: ChimeTime
ChimeTime
May 4, 2021
379
147
72
NE Georgia
Loren -
When starting out, I followed Willie's advice and found it to be spot-on.
When you have your #2 and #3 reamers, then you'll need to consider techniques to locate the reamed hole. I prefer a selection of small round files and these can be had from Contenti and/or Shor.
Hope this helps.
Loren Marcus
Jul 19, 2022
7
61
Thank you for the info, I will get them.
176,448
1,544,444
53,310
Toby2
1,064
3,031
