I need to get one of the basic must have tools even for the hobbyist like myself. A bushing tool and accessories. I've got the book "Clock Repair Basics" by Steven G. Conover and starting to go thru it and he talks about KWM, BERGEON and KEYSTONE. Not sure what a beginner would need to start out with. I'm trying to accumulate the necessary tools a little bit at a time since they are quite expensive. Can one of the clock guru's here suggest a basic bushing tool that would be right for a beginner hobbyist, just to maintain his own collection of mainly inexpensive mantel clocks? Even a used tool would be great.
I'll be tearing down for the first time one of the clocks in my collection for cleaning and repair, probably not a good one for a beginner to start out with because it's a three train movement with westminster chime, Junghans W64 movement (1952 year) Two bushing are worn out with pretty bad side to side play. This is on the chiming side first gear that meshes with the left side mainspring looking at the backside of the movement-pendulum side. One bushing on each plate worn out. All other bushings look pretty good.
When I think about it, In a way, it really doesn't make much sense for a hobbyist to spend $1000 + on a bushing tool so he can maintain a small collection of inexpensive mantel clocks with most of them only costing $50 or less. And additional tools probably required. Clock repair is an expensive endeavor to get into unless you can buy used tools dirt cheap.
Any ideas for a beginner hobbyist type bushing tool?
Appreciate the education and advice
Larry E Gosnell
Larry E Gosnell
