The New Year is the time when a lot of folks think about restocking their bushing box. Or those who do not have one think about making one set. There are a lot to a complete set. 147 in the case of KWM. One can make up a set that will cover 95% of all the pivots by using only the 3 mm height bushings. Once installed in the plate they can be cut down to flush with the plate by using a split point drill bit in a drill press. The entire plate can be done in a minute. Simply lay the plate over a large PVC plumbing coupler. No clamping is needed.
One can do the same with the Bergeon set.
