I don't know about the experience of others, but I have found that brass bushings seem to be a tighter fit than bronze ones of the same size. I have thought that perhaps the softer brass ones tend to "gall" a bit when driven in, helping them to stay tighter. The bronze ones are much harder, and tend not to gall.
I too run into the odd bushing that is too loose once the hole is reamed with an appropriate reamer. Fortunately, it is not a regular occurrence. Could it be that perhaps you had tried to insert a bushing that went in crooked, stretching the hole a bit on the way in? I use a hole closing punch to solve this kind of problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
