• For those of you who were having issues connecting to the Forums, it turns out that our modem was not functioning properly. We have replaced it now and the connection to the Forums has been restored. Thank you for your patience.
Bushing question.
legosnell
Nov 5, 2020
182
7
68
With a pivot size of 1.45mm would a bushing bore of 1.6mm be about right so that no reaming or smoothing would be required? bushing 2.7mm O.D x 1.4mm HEIGHT x 1.6mm BORE. Plate is 1.4mm
45,605
1,654
You could try it. Bushings compress as they are pressed into their holes, so your inner hole will be smaller after installing. Bushing work is a lot of trial and error, and often the ID has to be revisited after the bushing is installed.
Reactions: legosnell
howtorepairpendulumclocks
Dec 18, 2020
269
77
53
Consider a bush with a slightly smaller diameter hole than the pivot and open up with broaches or reamer to fit otherwise if the bush isn't completely perpendicular to the plate, although there looks to be clearance when you have the clock apart, you will/might run into uprighting issues. Within reason, it doesnt matter how much bigger the hole is (within reason!!!) as the pivot will be forced against the wall of the hole when in use. as always, it is depthing (mesh) that is important. Hope this helps.
13,164
1,200
Lego,
It is normal practice, in my shop, to hand fit every bushing. Also, every bushing needs to be tested before final assemly. I just outlined this on another thread.
R. Croswell
10,837
1,050
www.greenfieldclockshop.com
You can try the bushing on the pivot before installing in the plate. It will probably be a little too sloppy.
163,701
1,422,653
85,058
Willowind
2,861
Bread Upon the Waters by Tom McIntyre
