Hi Folks,
I recently ordered some needle files, broaches and a few other bits from Timesavers.
To be honest, this is the first chance I have had to look at what I bought despite having the goods for over 2 months now!
Anyway, the needles are labelled 3mm x 140mm x 12pc... and I received two packs the same an error on timesavers behalf. Problem seems to be that these files are not small enough to elongate the smaller pivot holes on the 0451 and 1151 movements.
I also ordered cutting broaches, a set 6 pieces 2.4mm to 6.20mm. These have plastic handles on. I bought the pin vice as well for the broaches.
Does the plastic handles need removing before locating in the pin vice??
Also I presume that needle files can be purchased in much smaller sizes? I haven't had time to check this out yet as been too busy.
Any advice will be gratefully received.
Cheers,
Simon
Cheers,
Simon
