Burnt Laser Cut Wooden Wheels and Pinions
Discussion in 'Wood Movement Clocks' started by mikejohn, Oct 3, 2014.
  1. mikejohn
    mikejohn New Member
    Aug 13, 2014
    Website editor
    Logan City, Queensland
    I want to share a bad experience I had with a laser cutting service cutting my wheels and pinions.
    I have a desire to build wooden geared clocks. These things are about the most precise thing you can cut out with a scroll saw and my chance of success was limited. Really, I hear these clock wheels and pinions can be temperamental.
    Plan A was to outsource the cutting of the gears to a laser cutting service. Fifty dollars later and I received a poor result in the mail when it was done. The burning is plain to see but the smell, which is not available on the Internet or at least not yet, was a burnt wood smell resembling a bush fire. I doubt the smell will ever leave the wood. My wife actually smelt it and suggested there must be a fire somewhere about here. I told her it was my clock wheels and I had to take it outside to the shed or I would go outside to the shed with my pillow and blanket.L A different laser cutting service may have been a good idea.
    So I have to discard them. I have decided to build a DIY CNC router and see what I can do with that.
    Hope this makes other aware of the risk of getting something cut by laser.
    Mike
    https://www.facebook.com/groups/woodengearedclocks/
  2. Kevin W.
    Kevin W. Registered User
    22,557
    379
    Hi Mike. I am in a group and we wish to make a wooden clock. One man in the group is going to try cutting with a laser. I guess we will see how it goes. I will have a look at the FB page.
  3. uglysteve
    uglysteve Registered User
    Sep 16, 2013
    Arizona
    #3 uglysteve, Oct 3, 2014
  4. Troy Livingston
    Troy Livingston Registered User
    Aug 28, 2006
    164
    20
    Aerospace Stress Engineer
    Melrose, FL
    I have seen examples of foam and steel pieces cut with water jet machines. This may work but I suspect you may be disappointed with the results.
    Mike, don't give up on those wheels quite yet. If memory serves I remember some discussion about removing the smoke smell in clocks that were in house fires with clay cat litter. You will likely need to remove the charred surface with a soft wire brush first. If the cat litter doesn't work perhaps one of the many odor neutralizing products on the market will help.
    While I am generally all in favor of new machining techniques you guys are over complicating things a wee bit. The tooth profile on these clocks is very simple, two flat faces with a rounded tip. All you really need is a small circular saw and some sort of indexing system.
    Just a thought.
    Troy
  5. mikejohn
    mikejohn New Member
    Aug 13, 2014
    Website editor
    That is an interesting tip with the cat litter and odor eating products. I never thought of that. I will investigate that plan of attack. I really thought the wheels a write off.
  6. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,101
    81
    Cambridge, UK
    As long as your kitty doesn't look down and think 'jeeez did I do that:???:'
  7. David S
    David S Registered User
    Dec 18, 2011
    7,201
    246
    Brockville, On Canada
    Mike perhaps baking soda would also work.
    David
