Electric WW Bulova accutron 2181 quartz conversion
aalinaman
Oct 8, 2012
I have a bulova accutron 2181 that is done for. The case is a solid gold case and i would like to still wear the watch. Does anyone know what quartz movement I could replace the 2181 with?
RJSoftware
Apr 15, 2005
8,833
272
Loxahatchee, Florida
I agree with Electro. But to each their own.
You might check into accuquartz. Not sure if they would fit but Samantha would know. One thing I can say about the genuine 218 movement is they are allot more interesting than a regular old quartz. The second hand sweeps flawlessly not jerky like a quartz and the hum of an Accutron is a pleasant thing to hear.
Samantha
Jun 28, 2009
915
22
Central Florida
aalinaman,
Years ago, Bulova provided a quartz retrofit kit for the 218's. It used a Swiss ETA movement, and was pretty good. However, nowadays I would recommend replacing the movement with another working 218 movement. The 218 is a good movement, and that would retain the originality of the watch. As RJ suggested, an Accuquartz movement would also fit in your case, however a working 224 (Accuquartz) movement may be harder to find.
Samantha
doug sinclair
Aug 27, 2000
14,363
77
Calgary, Alberta
I recall having seen a number of these "conversions" over the years. Samantha mentioned an ETA or ESA movement that was often used for this conversion. If the movement Samantha mentioned is the movement I have in mind, the conversion was crude. The calendar on the movement didn't line up perfectly with the opening in the dial, and the dial was held on with sticky tape, or glue! When you say the movement is "done for", can you elaborate? I would suggest that you only come to that conclusion after someone well acquainted with these movements has deemed it so! If someone at the local shopping centre watch repair kiosk told you that, I suggest that you should take that diagnosis with a grain of salt!
177,517
1,555,755
53,601
Krion
909
3,053
