(Originally posted on new message board site, but it cannot be seen from here)
This is my first time overhaul of Bulova 10COAC self-winding movement made in 1970 and while disassembling it I was puzzled by the offset center wheel mounting. It's pivot goes through a plate center jewel and press-fitted into pinion on the dial side (don't know the correct part name). At least I think it was a press fit because it was really hard to pull off. This pinion has an elongated "neck" on its bottom side. Finally, I was able to carefully remove it without damaging anything, although it took me some time.
Now is my question. What would be the correct way to reassemble it? How do I press fit the dial side pinion? Any help is greatly appreciated. Does anybody have a Technical Bulletin for this movement?
