Bulletin Links
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Aug 24, 2000
83,420
1,758
176
84
Boston
awco.org
The desired behavior is not yet implemented. If you do not have permission to view the article it should redirect you to the login facility and offer you the opportunity to join if you are not a member. If the result of that interaction is that you are a logged in member, it should display the article.
The behavior should be exactly the same for all protected material. It will require some work on the main site to create that behavior and it may take some rearranging of the file systems.
Staff online
161,034
1,397,114
82,997
Spiketock
1,099
2,788
