Bulle - to oil or not to oil, this has helped me make my decision
Discussion in 'Electric Horology' started by mopydick, Feb 13, 2017.
  1. mopydick
    mopydick Registered User
    Jul 12, 2016
    A Bulle just came in that is super original, including having its instructions on the inside of the back door.
    I've been oiling in limited places based on the belief that a clock movement is a clock movement - so why does would an electro-mechanical clock somehow not need oil?
    [​IMG]
      File size:
      671.9 KB
      972
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Unlike a spring wound clock, there is no load on the pivots.
    The oil is just there to reduce friction of highly loaded pivots.
    Oil is just a dust and dirt attracter.
    I don't oil my electric clocks like the Kundo.
  3. mopydick
    Jul 12, 2016
    Yes, I understand what you are saying - how EM clocks really don't have large torques within them versus a spring or weight driven clock.
    But the thought of metal to metal contact .... just gnawling at each other over time ... shivers down my spine ...
  4. John Hubby
    Sep 7, 2000
    11,291
    23
    The Woodlands, TX
    Tinker (and the Bulle instruction) is completely correct. Never put oil on electric clocks of the Bulle, Brillie, ATO, or similar types that have little or no load on the gears. One problem particularly on Bulles is that any oil migration (vapor, actual oil) to the "Y" contact yoke arbor bearings can cause poor electrical continuity and erratic operation.
  5. Tinker Dwight
    13,680
    Lubricating oils by their intent have high film strength. This is not true of
    all oils. Silicon oils have almost no film strength and are often used
    to both improve electrical contact and keep oxidizing air out.
Similar Threads - Bulle helped decision Forum Date
help ID clock --> horolovar? bulle? kundo? Electric Horology Jun 7, 2017
Bulle: Bulle Garde-Temps W Case Electric Horology May 27, 2017
Bulle: Bulle bar magnet question Electric Horology May 22, 2017
Bulle - have you every replaced your fork? Electric Horology Feb 28, 2017
