Can someone help with the correct order of operations for replacing the silk suspension spring in a Bulle clock? I have a replacement spring from Timesavers. It appears that if the spring is removed without supporting the pendulum, the fine hairspring will get stretched and distorted. This means that the pendulum would have to be completely stabilized in place while the spring is removed.
The lower chop of the suspension spring is held by a single bolt and nut; removal of that seems straight-forward. However, the upper chop is held by a threaded rod with nuts at both sides, and then on one side the rod continues with a series of nuts and insulating washers and a brass bar that acts as the electrical conductor to the hairspring. Is it necessary to disassemble this whole assembly in order to replace the suspension spring? To do that, is it necessary to disconnect the hairspring from the pendulum? There is also a second screw and nut towards one side of the upper chop, but this doesn't seem to go through the chop--at least the replacement doesn't have a hole in this location. I don't know what the purpose of this screw/nut combination is or whether it has to be removed or loosened to remove the suspension spring.
Here are pictures of the suspension spring from both sides and the top and also of the new spring.
Jeremy
Jeremy
