Bulle - have you every replaced your fork?
Discussion in 'Electric Horology' started by mopydick, Feb 28, 2017.
  1. mopydick
    mopydick Registered User
    Jul 12, 2016
    I'm having some trouble replacing the fork on this shaft. I can press the fork on, but the interference fit isn't very tight. It doesn't take much wiggling of the fork for it to fall off.
    I think the problem is the 'shelf' that the fork sits upon (red arrow) has taken on a profile similar to the light blue side view. If the profile was more like the yellow slide view, the fork would have a better matting surface to conduct its interference fit.
    Seems like I'm going to either have to machine the shaft a bit to make the interference surface square and true. Or, if I wanted to be a bit hacky, a dab of super glue could be a solution too, but I'm not too keen on this approach.
    I'm left wondering if the fork replacement procedure does normally involve a bit of clean-up machining or was I just unfortunate to have a shaft that has had its fork replace too many times leading to the shaft wear.
    Thanks for any comments,
    Peter
    [​IMG]
      File size:
      902 KB
      872
Similar Threads - Bulle every replaced Forum Date
Cord Replacement - wires broken at motor Electric Horology Mar 1, 2017
Bulle - I'm not exactly sure what I bought Electric Horology Feb 28, 2017
Bulle Wall clock Electric Horology Feb 24, 2017
Bulle - uneven case from factory? Electric Horology Feb 24, 2017
Bulle - to oil or not to oil, this has helped me make my decision Electric Horology Feb 13, 2017
