Bulle Clockette
instarclock
Mar 23, 2009
451
Galveston
Hello All
I finally got around to taking some photos of my newest clock. A Bulle Clockette in a four-glass and marble case. It’s been running steadily (although a little fast) since November.
I bought it at our local chapter’s one-day sale last November.
Thanks for looking.
Rt
F79F4032-E95B-4BB5-AF83-5CF8C49EF773.jpeg A133543A-EB2C-44D9-A4E6-BE365B532455.jpeg
PatH
Dec 5, 2014
1,923
1,366
Texas
Great clock! What are the case dimensions?
sophiebear0_0
Nov 5, 2012
80
Hi
Nice clock.
Its difficult to be 100% certain from your photos, but it does look like the iso-spring is under some tension. I base this on the separation of the coils. if you slacken off the tension in the iso spring a tad (by moving the lower bobbin up slightly), you will slow the clock down. The iso-spring adjustment is quite sensitive, and 1 mm movement in the spring will typically result in a change in timing of approx 5 mins /day.
Fine regulation is best achieved from adjusting the rating nut.
Peter
instarclock
Mar 23, 2009
451
Galveston
Hi
Nice clock.
Peter
Thanks Peter. You’re right, the clock does run a little fast. I haven’t done anything about it (so far) because I bought another, larger and older Bulle clock last August at a regional. I managed to totally destroy it by trying to adjust it before I understood how it worked. For now, I’m leaving this one alone. I’ll get the courage to tackle it someday. But for now it runs, and that’s more than I can say for the other one. :(
Thanks for the good advice and here’s my other Bulle clock.
Staff online
161,034
1,397,114
82,997
Spiketock
1,099
2,788
