Bulle Clock
Middlemarch
May 2, 2021
60
I have recently acquired a bulle clock and was wondering if it would be worth getting a bulle battery and hope that the clock works. I have enclosed photos of the mechanism to see if your expert advice could determine if there are any other parts that may be required. The serial number is 267636, which would date the clock to around 1924. Many thanks for your help.
IMG_20210502_122524.jpg IMG_20210502_121716.jpg IMG_20210502_121908.jpg IMG_20210502_121848.jpg IMG_20210502_121801.jpg IMG_20210502_121742.jpg IMG_20210502_111830.jpg
46,395
1,851
I can't see what the balance wheel is attached to. Does the movement indicate the voltage required?
Middlemarch
May 2, 2021
60
Thank you for your response, the only reference to the battery I can find is on the sticker underneath which states bulle battery no. 157? (maybe another digit).
IMG_20210502_130603.jpg IMG_20210502_130947.jpg IMG_20210502_131006.jpg IMG_20210502_131114.jpg IMG_20210502_130618.jpg
Jmeechie
Dec 8, 2010
371
72
Greetings,
Bulle clocks run in a 1.5 volt battery. The only Bulle battery available is aftermarket look alike s that hold a battery.
You can try picking up a C cell battery holder off the internet or a local hobby shop and try connecting to the leads in the base. You’ll need to clean those contacts and just temporarily clamp a wire to each terminal, it doesn’t matter about polarity.
I will suspect your clock may need serviced to run properly. The silver contact pin is usually dirty and a culprit for non running.
These are great clocks and yours is certainly a cut above. I have about 6 of these clocks and love watching them.
Cheers,
James
Middlemarch
May 2, 2021
60
Greetings,
Bulle clocks run in 1.5 volt battery. The only Bulle battery available is aftermarket look alike s that hold a battery.
Cheers,
James
Hi James,
Thank you for your advice, will give it a go as certainly yes I would absolutely love to see this clock up and running again if it's possible to fix.
Best regards - Sue
13,739
1,415
Midd,
Do a search for your clock, or Google it, to find the voltage required and the coil resistance, so you can check it.
A regular "C" alkaline battery will work for many, Battery clocks usually require either 1.5 or 3 volts. If it takes 3 volts, you can make (or buy) a holder for 2 "C" batteries.
I'm saying "C" battery's because it appears you have room. Use a "D" size, if you can. Or, "AA" if you have to.
Look around on the "electric" forum. You will likely find the info you need there
Willie.X
Jmeechie
Dec 8, 2010
371
72
Yours Doesn’t appear to have been messed with and appears complete which is a definite plus! The aftermarket Bulle battery holders are pricy and before taking that leap I’d certainly go the cheaper route if nothing else but for testing purposes. My suspicion is it was put away years ago when the replacement batteries became unavailable and has sat waiting on a return to life! One word of caution, take some paper and gently put it in the pendulum from both sides around the black magnet rod to prevent it from swinging too far to the sides while installing the battery. The isochronal spring as well as the suspension (cloth) are a bit delicate.
Good luck
Middlemarch
May 2, 2021
60
Midd,
Willie.X
Brilliant! Here goes, will post back if I can successfully bring it back to life
Sue x
Middlemarch
May 2, 2021
60
Good luck
I have noticed the very fine springs attached and am being very careful with moving it around. I am going to try and revive this old clock and will post if and when I do! I know nothing about clocks and the advice I have received is fantastic. Thank you for taking the time to respond to my enquiry
Sue x
Reactions: Jmeechie
Jmeechie
Dec 8, 2010
371
72
Here’s some helpful arrows of your pictures to help with what I posted earlier:
In the first picture this is the suspension and it is fabric as it insulates the pendulum.
In the second picture #1 is actually not a spring but rather a contact wire and is soft. It makes an electrical connection between the post and the frame. #2 is the isochronal spring. It compensates for temperature changes, modifying the arc of the pendulum swing.
Hope this helps.
8E67B432-4FD8-4D47-8E78-5E1F1B2B237C.jpeg 98D9A94A-89EC-409D-9E11-DF6935D6689E.jpeg
165,376
1,439,399
86,181
Kevsun
2,873
