I HAVE A WALL MODEL THAT I AM ATTEMPTING TO SORT OUT AND GET RUNNING.
I HAVE DONE ALL THE NORMAL ELECTRICAL CHECKS AND CLEAN UP INCLUDING THE HOROLOGIX
MAGNET AND COIL TEST USING 1.5 VOLTS WITH RESULTING GREAT PENDULUM SWING. CLEANED ALL CONTACTS AND CONNECTIONS.
RUNS ON 1.5 VOLTS BUT VERY POOR SWING. RUNS WELL ON 3 VOLTS.
BASED ON THE COIL AND MAGNET TEST SHOWING GOOD SWING ON 1.5 VOLTS IT LEADS ME TO BELIEVE SOMETHING IN THE MOVEMENT ITSELF IS CAUSING THE PROBLEM.
ANY IDEAS AS TO WHAT MAY BE CAUSING THIS?
