Building John Wilding’s small Tower Clock
Discussion in 'Clock Construction' started by Raynerd, Nov 3, 2018.
  1. Raynerd
    Raynerd Registered User
    Apr 11, 2004
    339
    Teacher of Chemistry
    Manchester - UK
    Evening all
    It has been quite some time since I built a clock from scratch. I’ve been busy with work and any time in the workshop I’ve spent working on my Cowells lathes. I’ve always wanted to build a Tower Clock and I’ve finally taken the plunge. I’m not entirely sure what I’m up against so I’m sure I’ll be posting plenty of questions on here as well as showing my progress! I have an idea where the final clock will go and hopefully it will drive an external dial. I’m sure it won’t be a quick project but with winter on it’s way, I’m hoping to spend some time in the workshop and hope to have it complete early in the new year.
    The plans have designs for both a deadbeat and a grasshopper escapement. I’m going to make it difficult and go for the grasshopper! The plans also show the option of chime and auto winding but these can be added at a later date!
    Wilding suggests using aluminium or steel due to the cost of brass. I was inclined to agree but after pricing it all up and with the understanding that the clock will be on full show in my dining room, I went with all brass.
    Part 1: introduction and Pillars.
    PatH likes this.
  2. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
    Looking forward to more, I remember your previous work.
    Raynerd likes this.
  3. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Well I’ve done a little more. Managed to bolt up the frame pieces and it’s lookijg good, nice and solid. I’ve just got to dowel pin it. I don’t really get why he has chosen to dowel it when it could be just bolted three ...anyway, I’ll follow the plans.
  4. Paul Madden
    Paul Madden Registered User
    Apr 24, 2017
    59
    Bienne, Switzerland
    Great work! Its fascinating to watch all the processes. Thanks for sharing!
    Raynerd likes this.
  5. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    I apologise for probably a nieve question but could someone please explain the arrangement of the main spring, click and especially the slip washer, in a weight driven clock. Whilst I have some vague idea how the components are arranged, i certainly don’t understand the function of the slip washer. Help appreciated.
  6. cmnewcomer
    cmnewcomer Registered User
    Mar 24, 2009
    Other's will probably be able to explain better but I will give it a try.
    It may be confusing if you are looking at the plans. They don't show the slot that would be turned into the arbor. This was probably intentional since you want to have everything made up in order to get the slot very close to the great wheel without slop. In some cases, the slip washer can be cupped to take up any slop.
    So, the slip washer retains the great wheel and keeps it from sliding out.
    Best Regards.
    Carl
    Raynerd likes this.
  7. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
  8. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
  9. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    My first error!
  10. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
  11. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    618
    41
    Tulsa, OK
    Thanks for sharing the good and bad. Actually not that bad since your "recovery" was first class work. I would not go back and remake the wheel. The repair is invisible and just as strong as the original. Looking forward to your next post.
    Allan
  12. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Thanks for the positive messages. Yes, I recovered quite well but was an idiot for making the mistake in the first place! Ratchet wheel next.
  13. jhe.1973
    jhe.1973 Registered User
    NAWCC Business
    Feb 12, 2011
    484
    Arizona, USA
    Hi Chris,
    First off I feel your work has always been of the highest order (including this repair) so saying you were an idiot just doesn't fit for me. I suspect that you may be harder on yourself than necessary - something we all are guilty of at times.
    Its getting close to 60 years that I have been at the metalworking craft, most of it professionally. Just last year I was replacing a damaged tooth in a spring barrel and not paying enough attention to the opposite end of the flycutter which was whacking two other good teeth. My repair job went from replacing the broken tooth to having to replace three. AAAARRRGGHHH!
    There, I'm much better now! :D
    Another reason I am writing is my concern of what might have happened to the brass by silver soldering. Since the plumbing industry has come up with an alternative to lead solder, the term silver solder has been thrown about too freely. If you used the plumbing style solder you may be alright. If you used what was formerly called silver solder, the higher melting temperature (800 to 1200 F.) has most certainly softened the brass at least in the repair area and quite possibly the entire piece.
    I would hate to see you go through so much more work of the high quality that you do, only to find the teeth bending over from being too soft or wearing too quickly.
    There might be another solution to suggest. My second generation regulator clocks that I have yet to complete use 5/16 thick brass for the plates. I have way more than I will ever use and I have been clearing out projects etc. that will never happen. I would be happy to cut a 5 X 5 piece to send you at no charge. People in the NAWCC have been quite generous with each other and I try to keep the spirit alive as I feel we all have to contribute where we can.
    If you are able to utilize the slightly narrower piece for your great wheel, please send me an e-mail. My website address is on the left and it includes an e-mail address.
  14. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
    I was wondering about that when I watched the clip. Not really aware of the temperatures involved. Does machining do any work hardening?
  15. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Great reply, I hadn't considered that. It was indeed silver solder and I had to get it hot hot hot...I struggled actually. Your offer is very kind and I will have to offer to cover postage at least. I'll send you an email. Whilst I would be happy to plod on with the only concern being asthetics, I would be quite disappointed if the teeth started to bend!
    All the best.
    Chris
  16. jhe.1973
    NAWCC Business
    Feb 12, 2011
    484
    Arizona, USA
    Great question! This brings up a few perspectives.
    The practical answer when cutting most metals is, no it does not because the metal is being peeled away by machining and not being "worked". I would not be surprised however if at the microscopic level there is a tiny bit of hardening going on but subsequent cuts taken break right through a tiny skin.
    One of the notable exceptions however is with stainless steel. Stainless is actually rather soft and machines easily IF the cutting tool is very sharp and the crafts-person maintains sufficient pressure on the tool to assure it does not skid. Once a tool skids it creates a hard skin very quickly and can give the operator the impression that stainless is difficult to machine. In fact, once the surface work hardens it can easily be impossible to make any more progress even with a sharpened tool and a person may have to go to a much harder cutting tool - or, if possible, cut from the other side, breaking through the hard skin from inside out.
    Several of the tool steels also act in the same way (D-2 comes to mind). With D-2 it is fairly easy to take rather deep cuts, but if you try to skim off a few thousandths the cutting tool quickly dulls.
    Another perspective I want to mention is that the shaving coming off of a part IS being "worked" and is harder than the part it is leaving. This is why if a chip sticks (welds) to the cutting edge it will likely change the surface finish on the part. When inspected under magnification it is apparent that metal shavings are small segments packed together and forming a longer string.
    Just a bit of trivia that I was going to mention in my last post and forgot. (this age thing really sucks sometimes) For decades I have maintained that the measure of a true craft-person is by how well they can get out of their mistakes. I think that Chris did an outstanding job as far as being able to detect the repair.
  17. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
    Is this a case where soft solder could be used? If the fit is as good as this then all you want to do is stop it sliding out and filling in the very small gap between the two.
    It was stainless that made me think machining work hardened, thank you for the explanation. ( The company I worked for over 40 years ago broached stainless and nimonic alloys and I thought I recalled the work hardening)
  18. John MacArthur
    Feb 13, 2007
    324
    27
    I use Stay-Brite silver bearing solder for almost everything. It flows at lower than annealing temp of brass or tempering temp of steel, is stronger than lead solder, and melts and flows very easily.
    Johnny
    ernienoa likes this.
  19. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Evening. I’ve been busy with work this week and therefore I’ve had very little time for the Clock build! I’m normally one video ahead of what I’m posting but right now I’ve literally just finished the ratchet wheel. It turned out quite well and I liked the finish from the dovetail cutter compared to my effort sharpening a fly cutter!
  20. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
  21. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Marking mocks, planning lessons, assemblies, marking books, parents evenings...take your pick ;)
  22. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
    I see it all, then go back to my preproom :)
    Raynerd likes this.
  23. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    For anyone who has built this clock or anyone with suggestions...the lantern pinions call for 54 gauge pivot wire. I can not buy this new. The only option I have is 1.3mm or 1.4mm. Marginally too small or too large. Anyone know a source of 54 gauge pivot steel or any thoughts on which you would go for...to big or small. My thought is to go on the smaller side to avoid binding?
  24. David S
    David S Registered User
    Dec 18, 2011
    7,173
    236
    Brockville, On Canada
    are you sure it is 54 gauge?
    That is pretty small this side of the pond.
    David
  25. David S
    Dec 18, 2011
    7,173
    236
    David
  26. novicetimekeeper
    Jul 26, 2015
    9,298
    490
    Dorset
    54 gauge? Is that AWG? SWG doesn't go that small does it? Or does pivot wire have its own gauge system?
  27. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,583
    437
    Magnolia, TX
    #26 Jim DuBois, Dec 12, 2018
    54 gauge doesn't compute for me in either AWG or SWG. But, here is a source that has a large range of sizes https://www.onlinemetals.com/merchant.cfm?id=1214&step=2 but they seem to sell it in 1 pound quantities. It is in .002" increments in their smaller sizes and is "music wire" but I have used that in a fair number of lantern pinions. I would think that would be fine for a weight driven clock.....does the spec sheet call for anything sizewise besides 54 gauge? A inch or MM size would help if it were me building the clock....I work in both, but by gauge? Not so much....
    Maybe drill size 54? That makes some degree of sense to me
  28. Phil Burman
    Phil Burman Registered User
    Mar 8, 2014
    173
    17
    Suffolk England
    A ratterly gear train is a good sound, a binding gear train is bad news, so I think your selected option is the correct one.
    Phil
  29. cmnewcomer
    Mar 24, 2009
    Looking at the plans it seems that it should have been 16 gauge (#54 Drill) as Jim pointed out. So 1.3mm should be fine unless you want a press fit.
    Best Regards.
    Carl
  30. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    Evening, the plans I have state 54 gauge. I agree that this must refer to drill size 54 which is actually 1.397mm.
    However, I was wrong before, I should have said I can get only 1.3mm or 1.5mm ! However, based on the advice you have been giving, I’m guessing 1.3mm is the way to go rather than having 1.5mm and it binding.
    Chris
  31. Phil Burman
    Mar 8, 2014
    173
    17
    Suffolk England
    There are lots of sources of 14mm piano wire. Google "1.4mm piano wire".
    Phil
  32. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    I had seen this in my searching but didn’t think it would be a suitable alternative.
  33. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    A bit of a long delay! Back at it now....
    Paul Madden likes this.
  34. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    A little bit slow but some progress....
  35. Raynerd
    Apr 11, 2004
    339
    Manchester - UK
    And the click assembly ....
    Paul Madden and 24clok like this.
  36. 24clok
    24clok New Member
    Oct 1, 2013
    Mechanical Technician
    Perth Western Australia
  37. Paul Madden
    Apr 24, 2017
    59
    Bienne, Switzerland
    Looking great Chris. Thanks for taking the time to video your progress and sharing with us.
    Keep up the posts!
    Paul.
  38. scootermcrad
    scootermcrad Registered User
    Mar 1, 2016
    264
    This is GREAT, Chris! Thank you for sharing your build. I will be following along.
  39. FDelGreco
    FDelGreco Registered User
    NAWCC Star Fellow NAWCC Member Sponsor
    Aug 28, 2000
    1,885
    52
    Retired chemical engineer
    Novelty, OH
    Chris:
    I just saw this thread and have spent time viewing all of your videos. You're doing a super job. I have a copy of Wilding's book -- for more than 10 years now -- and have been meaning to build that clock but other priorities always seem to nudge it out of the pipeline.
    I saw a completed clock at NAWCC's Eastern States regional a couple of years ago. It wasn't for sale, just for show. However, you made a comment in I think your second video where you said it was a nice size clock. I have been thinking of building a 2x scale version, especially when I saw it at the regional. I think it's too small! Of course, I have 10 tower clocks in my home and they are all bigger than Wilding's clock!
    Keep up the good work!
    Frank
  40. Pensivedoc
    Pensivedoc Registered User
    Jan 29, 2020
    12
    Physician
    Fun to follow along. Thanks for the videos!
