• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
BUCO clock parts
Lcodd6
New Member
May 13, 2015
Hello,
i received this Buamann CH-9444 clock from my grandmother. I don't know much about it but I would like to get it working. It's missing the two weights and clock hand cap. Does anyone know where I can get these? Is it not worth it?
any help would be greatly appreciated. image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
leeinv66
Mar 31, 2005
10,199
264
Launceston Tasmania
Hi there Lcodd6, these clocks are considered novelty clocks and were made by several different manufacturers. Any parts you are missing will have to be made or sourced from a donor clock as none are available from any parts supplier. These are not particularly valuable clocks, but they are fun to watch in action (I own several). Here is a thread devoted to these clocks. Click Here
Burkhard Rasch
Jun 1, 2007
4,884
181
64
Twistringen
please show a closeup of the central shaft.If my memory still serves me the single hand is pinned without a cap.For weights use two plain field stones ,one of ca. 1 kilogram and one of about 250 gramms and a hemp rope of about 5mm thickness.Try to wrap the rope around the stones in a kind of basket manner and get the rope in the (rough) slot of the rope wheel (lowest).The difference of the weights will let the clock go with the small weight pulling the rope into the nodge of the wheel.It looks like everything else is there,the pin can be cut from a match or a toothprick .HTH
Burkhard
