Broken Tallcase Pinion Leaf - Advice Needed
David D'Apice
Mar 22, 2012
239
10
Good evening. Sadly, the English tallcase movement I'm playing with seems to have been hiding a pretty disappointing missing pinion leaf on the gear that trips the bell hammer -- I can see some porosity and crystallization --- perhaps the spring was made too strong on the hammer, and some backlash cracked this leaf free some time ago. (disappointing cartoon sound effect) ---- anyway -- does anyone have a good method of solving this, short of a complete re-cut, which is beyond my skill level. Any advice would be helpful. Thanks in advance.
46,395
1,851
Your best bet is to have one made for you. I often farm out that kind of repair to David LaBounty. He does great work at a reasonable price. I'm sure there are others capable of making a new arbor for you too.
Jerry Kieffer
May 31, 2005
2,930
552
wisconsin
There are three options that I can see.
(1) If for preservation or value reasons, it can be repaired. In this case, a slot can be machined about half depth into the arbor and a new leaf blank silver soldered in place. The blank would then be machined to match the other leafs.
(2) In some lucky cases, pinion wire is available in appropriate size requiring only that the arbor be machined.
(3) Your most likely option will be to have a new pinion/arbor machined as mentioned by Shutterbug.
Jerry Kieffer
5,072
631
Jerry,
I never had luck finding pinion wire suitable for clocks. What I found was much too large and had the wrong tooth profiles. Is there a source for them still around?
Jerry Kieffer
May 31, 2005
2,930
552
wisconsin
Jerry,
As mentioned , its a get lucky thing, but one never knows.
I generally google my exact needs, but when that fails to work my favorite source is the following link.
Miniature Metric Gears - SDP/SI
I generally call and discuss my needs. Very helpful people.
Jerry Kieffer
5,072
631
Jerry Kieffer
Thank you Jerry!
It's amazing what you can find when you know where to look! And the prices seem to be quite reasonable.
David D'Apice
Mar 22, 2012
239
10
You guys are the best ----- I didn't know any of these resources even existed --- you learn something new every day! Thank you so much.
165,377
1,439,419
86,182
Mike Craft
2,873
