Broken Arbor/ Hamberg American
Discussion in 'Clock Repair' started by disciple_dan, Aug 17, 2019.
  1. disciple_dan
    disciple_dan Registered User
    Mar 10, 2016
    409
    24
    Clockmaker, General Flunky
    Apopka, Fl.
    Boy, I've really done it now.
    20190817_193509Broken.jpg 20190817_193458Broken1.jpg 20190817_193435Broken2.jpg 20190313_210818.jpg
    Does anyone know where I can get a warning wheel on the chime side for this Hamberg American?
    I was polishing the pivot on the side with the pin in it. Need I say more.
    The wheel dia. is 24.67 mm. The wheel has 64 teeth. It has a 7 leaf pinion with a dia. of 3.18 mm. The arbor length is 35.57 mm (Between Plates) and the overall arbor length is 40.18 mm. Pivot dia. is 0.62 mm.
    If anybody has one please let me know. I will give you whatever you have to have for it.
    I have been working on this clock for some time. I own it and it has much value for me. I have just finished putting 23 bushings in it. 20 of them were replacement bushings but they were all Bergeon and I had to purchase all the Bergeon equipment to do it. Which I'm glad I did.
    Anyway, I have a lot of time and love in this clock and I was going to have it back together and on the test stand before bedtime tonight. Oh. well. life happens.
    Please help if you can. I'll buy the whole movement if you have one to sell.
    Thanks, disciple_dan.
  2. shutterbug
    40,799
    732
    That sucks! You could have a new arbor made and re-stake the wheel.
  3. disciple_dan
    Mar 10, 2016
    409
    24
    Apopka, Fl.
    Can you make one? What would I do, take the wheel and collet off and press it on the new arbor?
  4. shutterbug
    40,799
    732
    This guy does great work and could fix you up.
    disciple_dan likes this.
  5. wow
    wow Registered User
    Jun 24, 2008
    3,583
    162
    Retired Music Minister
    Pineville, La. (central La.)
    Dan, I may have the whole thing or the arbor but I would need detailed measurements or just send me the whole thing and I’ll look through my bone pile. Let me know if you are interested.
    Will
  6. disciple_dan
    Mar 10, 2016
    409
    24
    Apopka, Fl.
    Thanks, fellows.
    Yes, Will, I am interested. I jotted down some measurements in post #1. Tell me which measurements you need and I'll get them to you right away. If you have something you think might work and need to verify it with the original then I'll send it to you.
    Than you both for the replies. Danny
  7. wow
    wow Registered User
    Jun 24, 2008
    3,583
    162
    Dan, yes, those measurements should work. I am out of town tomorrow morning but should be able to look tomorrow afternoon. A close-up photo of each piece would help to try to match it exactly. Also, I need the distance from the pinion to each end of each pivot.
  8. disciple_dan
    Mar 10, 2016
    409
    24
    Apopka, Fl.
    The pinion leaf measures 5.80 mm. On the long end of the arbor, from the shoulder to the pinion it's 25.13 mm. To the best I could measure it on the short end, shoulder to leaf, it's 5.82 mm. I measured shoulder to shoulder on many of the other arbors and they varied a bit but the longest was 36.70 mm. Most were around 36.64 mm.
    Let me know if you need any more info. I really appreciate it, Will.
  9. wow
    wow Registered User
    Jun 24, 2008
    3,583
    162
    Dan, I looked through several drawers of wheels/arbors etc. found several that are close but not right. That’s a long arbor, a small pinion, and a small wheel. My other parts shed is not air conditioned and the temp here is 93 and going up. I’ll look again tomorrow morning when it’s cooler out. My movements are in that shed.
  10. disciple_dan
    Mar 10, 2016
    409
    24
    Apopka, Fl.
    Yeah, I live in central Florida, I know what you mean. Thanks for the help.
  11. wow
    wow Registered User
    Jun 24, 2008
    3,583
    162
    I looked through my movements and do not have that one. Sorry. If you have a lathe you could drill both ends of the arbor where it broke and insert a pin. Use loctite or silver bearing solder to secure it. Both holes must, of course, be centered. That wheel does not have much power on it so it should hold. Just must be straight.
  12. disciple_dan
    Mar 10, 2016
    409
    24
    Apopka, Fl.
    No, I don't have the means to do that. Do you have any other ideas?
  13. Vernon
    Vernon Registered User
    NAWCC Member Donor
    Dec 9, 2006
    534
    31
    Gardener/Arborist
    Go with Shutterbugs suggestion in post #4. I've had David do a few repairs for me and he is fare and does quality work. Otherwise, you may find someone at your local Nawcc meeting.
