Brocot Escapement - Need Opinions
Discussion in 'Clock Repair' started by djstucker, Mar 14, 2017.
  1. djstucker
    djstucker Registered User
    May 28, 2016
    29
    Engineer
    Valencia, CA
    So I have an Ansonia Crystal regulator I rebuilt the movement on about 6 months ago. I completely overhauled it, bushings, polished the pivots, etc. I installed one new jewel that was missing and verified the escapement dimensions were correct. It ran okay, but you could definitely see it was low on power. It would occasionally stop; I went through the whole movement again with no issues found. I have always read that you should never oil a jeweled Brocot, so naturally, I didn't. After monkeying with this thing on and off over several months, I finally decided before I tear it down again, let me try a tiny amount of oil on the escapement pallets. Wouldn't you know it; it is running amazingly well with twice the amount of pendulum swing that it had. The drops look much more snappy. So, what is everyone's opinion on this? I have heard arguments both ways. Oil or no oil?
  2. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,882
    7
    watchmaker
    sydney Australia
    With the exception of a Daniels watch escapement you always oil or lubricate the escapement, I use an escapement grease 9415 which works really well, stays put doesn't run away like oil can.
    I have no idea why people think just because the pallets are jewelled you don't need oil, watch escapements have jewelled pallets, it they are not lubricated the watch will run for a while but will give a bad action and eventually will stop.
  3. djstucker
    May 28, 2016
    29
    Engineer
    Valencia, CA
    I'm with you. Friction is friction. Even though the jewel is very smooth, you still have two surfaces sliding across each other, and when there is not a whole lot of torque (as there is not at the end of the train) it doesn't take much friction to slow/stop the action. I'm convinced I should lube them from now on.
  4. Kevin W.
    Kevin W. Registered User
    20,163
    10
    Interesting thread, i would have thought of not lubing them. I have found with watches, some run better with a dab on the pallet faces and some do not run better.
  5. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,867
    watchmaker
    Western NSW, Australia
    I was taught to oil both faces of each pallet stone and not oil the pivots.
    Mostly, a stopped watch will attempt to run or start going, if a dab of oil is put on the pallets.
    I've never seen any watch or clock run better without oiled pallet faces.
  6. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    625
    Science teacher, writer
    Lancaster, Ohio, USA
    Including dead-beat escapements? I thought oil was verboten on those.
    Hmmm.
    Mark Kinsler
  7. Jerry Kieffer
    Jerry Kieffer Registered User
    May 31, 2005
    1,815
    wisconsin
    Its all about removing friction. If one part slides on another part, the assembly will benefit from or may require lubrication. However, lubrication can create friction itself under the right conditions. For example, in a watch where very little power is supplied, lubrication that is to heavy or to thick of viscosity, will increase resistance to the point the movement may not run. The manufacturer of the movement and manufacturer of the lubrication will have the most experience with this issue and their recommendations should be followed for best results.
    On common clock movements with steel verges, they should also be returned to original condition for proper operation that includes sharp release edges for maximum impulse strength. Personally, I grind all steel surfaces as originally done by the manufacturer to restore proper operation.
    Jerry Kieffer
  8. roughbarked
    Dec 2, 2016
    1,867
    watchmaker
    Yes. All this information is sound. The correct lubricant is important. It is wise to examine the pallet faces and return them to original condition as part of every service.
  9. djstucker
    May 28, 2016
    29
    Engineer
    Valencia, CA
    Thank you all for confirming.
    I battled this problem for months that turned out to be the fact that the escapement was not oiled. And yes, absolutely agree with making sure the pallet faces are maintained.
  10. bruce linde
    bruce linde Technical Admin
    1,778
    I have two S. Thomas 68 movements… deadbeat escapements and jeweled pallets. They both run way happier with a hint of oil on the pallets.
Similar Threads - Brocot Escapement Need Forum Date
Looking for a reading on adjusting a Brocot escapement. Clock Repair Nov 12, 2016
French mantle clock with Brocot escapement Clock Repair May 1, 2016
Experiment! Mounting pallet jewels in a Brocot escapement Clock Repair Jul 11, 2015
Seth Thomas Brocot Escapement Question Clock Repair Feb 9, 2015
Brocot Escapement Japy Has Problems Clock Repair Feb 1, 2015
