Brille slave clocks
Discussion in 'Electric Horology' started by tickntock1, Nov 27, 2016.
  1. tickntock1
    tickntock1 Registered User
    Feb 27, 2002
    211
    #1 tickntock1, Nov 27, 2016
    Hello,
    I have two Brille slaves - using a Piexx slave driver to run both, will the setting for a brille at 1 1/2 volts send a voltage of 1 1/2 to each or should I use the 3 volt setting in the hope that each will receive 1 1/2 volts? Stupid question, I know, but electricity is on the same order of understanding as Greek!
    thanks, jim
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    162
    deceased
    It will depend on whether they are run in series or in parallel. In series each will get 1 1/2 volts, in parallel each get 3 volts.
