Brass Stringing
Discussion in 'Clock Construction' started by bclare, Feb 16, 2017.
  1. bclare
    bclare New Member
    Feb 16, 2017
    I am constructing a longcase clock and I am wondering if anyone knows how brass stinging was originally fixed to fluted columns.Cheers,Bill.
  2. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,583
    73
    Cabinetmaker,clock repair
    Moultonborough,NH
    Hi,
    It has been my experience that the brass infill on fluted columns has been halfround brass. Either it came that was or was filed to shape-I do not know. To attach one end is bent to 90 degrees and it is inserted in a hole in the flute. The other end is retained by the brass capitol/base.
    Hope this helps.
    tom
  3. upstateny
    upstateny Registered User
    Oct 2, 2015
    521
    19
    I have done it on Willard replicas just the way Tom suggests above. Some folks just like the brass added to a clock without the capitals. In that case I drill brass rod for a brass tapered pin, mount the brass in the flute with tape, and drive the pin through the brass into the wood. Then file the brass pin flush with the surface, and polish with a Dremel. As in the photo below. I know others when faced with the same situation to use glue (e-6000) to in addition to a pin adhere the brass to the case.
  4. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,000
    86
    El Dorado, CA
    I'd drill and solder brass wire into the rods at 2 or 3 places and make them into tacks.
  5. upstateny
    Oct 2, 2015
    521
    19
    That would also work, good idea!
  6. bclare
    bclare New Member
    Feb 16, 2017
    Thanks everyone for the replies, I have prepared the columns to take full round brass so I think Martin's method may be the way to go,Thanks,Bill
  7. upstateny
    Oct 2, 2015
    521
    19
    Cool! Remember to pre-drill your column for your tacks. Brass is soft and my fear would be that it would bend when being driven into wood that has not been pre-drilled.
  8. bclare
    bclare New Member
    Feb 16, 2017
    Yes,I thought I would take some brass the same size as the stringing and drill holes though it and use that as a template to spot the stinging and predrill the flutes.
  9. Bill Ward
    Bill Ward Registered User
    Jan 8, 2003
    1,224
    EE (spec. acoustics) now medicine
    USA
    Some antique ones I've seen were cast brass, with steel brads cast in. The section was not a full round, but rather a sort of ellipse, so that they don't stand proud of the fillets between the flutes. This profile was also used in architecture.
  10. david friedman
    david friedman New Member
    Mar 22, 2017
    Your posts have all been very informative. Does anyone know where I can buy brass stringing to put into my Georgian tall case clock? Thanks.
    Dave
  11. MartinM
    Jun 24, 2011
    3,000
    86
    El Dorado, CA
  12. MartinM
    Jun 24, 2011
    3,000
    86
    El Dorado, CA
  13. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,691
    75
