I have been repairing clocks for 32 years. On occasion, I will place a dirty clock movement in my heated ultrasonic cleaning tank and after 3 to 4 cycles (for a really dirty movement) the brass will start to turn a dark copper color, and sometimes nearly black. I use non ammoniated water based cleaner because the strong smelling ammoniated cleaners are just too much for indoor use. I am currently using POLY-CHEM DEOX-007. And this discoloration just happened in an almost brand new batch. Anyway, when this happens, I spend a lot of time with a toothbrush and various cleaners to remove the discoloration. Actually, when this happened to me just a few days ago, I did mix a small batch of ammonia based cleaner outdoors in a plastic bucket, soaked the badly discolored movement in that for about half an hour and it was back to gleaming brass. Does anybody have any ideas what it is that causes this discoloration to happen? I do think a common theme for me when this has happened, is that someone in the past has done some soldering on the old brass movement. Could it be that the lead based solder has a reaction with the cleaning solution? Any ideas would be appreciated.
Also, if anybody knows where I can find HISTORIC TIMEKEEPERS ultrasonic cleaning solution it was always my favorite, but seems to be out of production
