Right. In addition, the most important variable is the condition of the pivot, the material and how well it is polished. Hermle has experienced catastrophic wear on some of the bronze bushings when the pivots were not properly polished.IMOE, bronze will last longer 'IF' you keep it oiled. If/when the oil goes away, the bronze will roughen and wear away the pivot faster than brass will. There are many pros and cons but for me there is a slight edge toward using the brass, so I do.
............so should one assume that bronze is so much in demand that the supplier can't keep it in stock, or that there is so little call for it that it is not practical for the supplier keep it in stock?EVERY time I order bushings from the clock supply house bronze is out of stock and I need to settle for brass.
