Brass Marine Gallery Clock Case
Discussion in 'General Clock Discussions' started by Bruce Barnes, Mar 22, 2013.
  1. Bruce Barnes
    Bruce Barnes Registered User
    Mar 20, 2004
    1,863
    19
    I am looking at the above captioned clock and the original works are missing.The dial has the two ports for the arbors but the F/S adjustment lever is accessed from the back of the case at the 12 o'clock position.
    Does anyone have a clue as to who made a balance wheel mechanism that the F/S is adjusted through an aperture at the back plate:???:
    Thanks,
    Bruce
  2. soaringjoy
    soaringjoy Registered User
    Feb 12, 2009
    7,238
    20
    Bruce, are you talking ships bell clock?
    German makers for instance called almost all of their balance wheel wall clocks "marine clocks".
    Maybe you can show us the case.
  3. Steven Thornberry
    Jan 15, 2004
    21,114
    705
    Ne’er do well
    Here and there
    Possibly New Haven. I have their porcelain clock the Thistle. Time only with double winding arbors. The S/F lever is accessed by opening a round door. In a brass case, possibly the same movement could be used with an acess point through an aperture as you describe (if I am understanding you correctly. Let's see the pix. Below is what I have on the Thistle.
  4. Bruce Barnes
    Mar 20, 2004
    1,863
    19
    Thanks Gentlemen,this is a time only,all brass gallery type clock and the adjustment lever/bar would exit from am opening at the top rear of the case just below the circular casting rim.It is currently at auction so I can't post pictures. The case is like this one that I own Gay Engineering.jpg
    Bruce
  5. Uhralt
    Uhralt Registered User
    3,821
    375
    This is strange. I see the slow-fast opening on the dial, right below the XII. My guess for the clock in the picture is that it has the ST#10 movement. We have seen a similar clock in this forum before.SUhralt
  6. Bruce Barnes
    Mar 20, 2004
    1,863
    19
    Uhralt,you are correct.......this is my clock (in the photo) I used as an example of the case and clock in question
  7. Uhralt
    3,821
    375
    Ohh, sorry I misunderstood.
