Brass bushings on Terry movement--original?
jboger
Jan 7, 2019
844
325
66
Would appreciate if someone could tell me if the brass bushings on this Eli Terry & Son movement are original to the movement or added later. I dismantled and cleaned the movement, then re-assembled the basic time part of the clock. It runs quite well with good motion to the pendulum.
John
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
3,973
1,552
Magnolia, TX
I suspect they are a later addition. Not quite right appearance-wise for a factory job. This is Henry Terry with original bushings, we think.
jboger
Jan 7, 2019
844
325
66
What I find odd about mine is that every pivot is bushed, including those you might not think necessary. By that I mean the pivots for the Strike-side levers in the upper left-hand corner of the movement. Why bother? Are yours bushed?
Jim DuBois
Jun 14, 2008
3,973
1,552
Magnolia, TX
yeah, the bushing in areas that don't experience much if any wear was the clue as to a later effort
jboger
Jan 7, 2019
844
325
66
It was an adequate job. The clock ran the whole night. I will put the entire movement back together now. Thanks.
jboger
Jan 7, 2019
844
325
66
One other things. All the wheels match. I believe they are all original to each other. Even with interchangeable parts, there can be differences in the turnings. These all match. What seems unusual to me is that not a single wheel is damaged. No repaired teeth. Nothing. Just wear.
I'm convinced the bushings are a later addition. Thanks again.
John
177,714
1,557,620
53,661
sara.fagan73
909
3,061
