I recently posted a request for information about identifying a bracket clock but since I've never actually recovered one from its home on its bracket I have been seeking wisdom on just how to move it also.
1. It is heavy
2. It is quite high up
3. It has a pendulum
4. There is no access to said pendulum as there is barely enough space for a finger let alone opening the door
Since the clock needs to be serviced (not been serviced in 30 years) and repaired (runs fast, chime and strike issues) I need to move it but I find myself somewhat intimidated, particularly since it looks like I need to move it initially with the pendulum in place. Once I have done the service etc I will need to put it back and set it up - but how on earth do you set a clock in beat and regulate should it be necessary if there is no access - surely it needs to be set up on its bracket and not my bench - can't see any way to level it once on the bracket and it is perfectly in beat right now.
1. It is heavy
