Bought a pocket watch case is it worth anything?
edteach
May 9, 2016
123
47
Its a Duber size 18 I believe key wind watch case. Silverine. I polished it up and it looks good. All the case covers are fine and snap closed. Glass is the thick crystal and in good condition. I have no idea if it has value or if its not worth anything. I was also thinking of putting in a new movement if anyone has a recommendation
. Thanks
mosesgodfrey
Aug 30, 2017
688
585
93
Howdy—I believe silverine is a base metal, but there’s probably $50-$100 in having a complete case. If you look around, likely a nice movement will present itself.
musicguy
Jan 12, 2017
11,390
9,174
New York State
It's an American case maybe $10-$25 it's a nickel alloy case.
Rob
Appa69
Apr 3, 2022
414
318
44
It's a fine case. I like nickel cases best because they are durable and you don't have to worry about wearing through to a different metal underneath. This case is for a key-wound movement. I would recommend trying to source an American movement to fit in it. Definitely a very good starting point.
I'm unsure if all key-wound cases had the key holes in the same place or not. Perhaps someone else could educate us on that and maybe what movements might work well in there.
Appa69
Apr 3, 2022
414
318
44
edteach
May 9, 2016
123
47
I picked this on up just a bit ago on eBay. Says its running. I will have to source a key. Should fit my case. I found most all the major watch makers that have the same case in size 18. BTW what does KS KW mean. I get the key wind one but KS?
edteach
May 9, 2016
123
47
I don't know the size key and will wait to get the movement and measure with my micrometer.
MrRoundel
Dec 28, 2010
2,646
1,145
Don't be surprised if the movement has a different dial, or the dial has a different movement. The dial in the image is an "American Watch Co." dial. If it's on a Hampden, it's out of place. It also reminds me a lot of the dials that are on some early Waltham model 72's.
Or, again, am I missing something?
edteach
May 9, 2016
123
47
I will look at it once its here. If the dial is something that bothers me for 20 bucks I can get an Illinois one on ebay.
Dave Coatsworth
Senior Administrator
Business Member
Feb 11, 2005
9,813
4,777
Camarillo, CA
www.daveswatchparts.com
The Illinois uses a '4' key.
The American dial is a nice one if that's what you get. Probably worth more than the movement. (As long as no one has sawed off the feet.)
topspin
Dec 14, 2014
1,863
755
If (heaven forbid) all else fails - you can always start again, with either a private label or a Swiss Fake. Guaranteed to at least look pretty interesting if nothing else.
terry hall
Silver Member
Apr 12, 2001
7,338
1,126
Central North Carolina
For the new movement... there will probably be a small locating pin on the outer diameter of the movement, this pin will insert into a corresponding hole in the case.. there's many that have had that pin filed down, but it actually helps to locate the movement correctly and maintain alignment with the key hole.
Yes, location of the key hole can vary between manufacturers
Sometimes the end of the key can be worn enough to not engage with the square for setting the hands, this occurs with old, vintage keys... I have seen some keys with the 'excess' filed off to get a good square all the way to the edge.
good luck!
Appa69
Apr 3, 2022
414
318
44
The dial is on an Illinois Watch Co. Movement, so it is a mixed up mess.
I hadn't noticed... I'm actually a bit surprised that they would fit together. Didn't most manufacturers have dial feet in different locations?
Paul Regan
Mar 4, 2003
820
281
Florida
If my memory serves me right, I think that is a fairly scarce AWCo dial with “arrows in” at 5 min markers and script signature. Should be on a high grade AWC movement.
Paul
Jim Haney
Sep 21, 2002
7,837
3,395
Decatur, TN.
The Gold book give dial feet locations on all dials,maybe a match, doubtful, most people use dial dots, small 2 sided adhesive that let dials without feet be mounted on anything with the same plate size.
Dave Coatsworth
Business Member
Feb 11, 2005
9,813
4,777
Camarillo, CA
Elgin and Waltham used the same dial foot locations for most of their 18-size movements: 16.5, 36.5 and 54.0. Illinois is close at 16.5, 36.5 and 53.0. My guess is that the dial has one foot clipped to fit the Illinois movement.
edteach
May 9, 2016
123
47
As long as it fits and runs I am not sure I care about the dial being wrong. Could very well be an old repair. My only worry is that the hole in the case does not line up right with the key wind. Seller takes returns so if all fails I can return it. I can look on eBay for an Illinois size 18 dial and then sell this one or keep it in case I run across a Waltham that needs a dial. Or maybe I will look for a nice 18 Waltham that has a bad dial on it and a case and just add another watch to the collection.
edteach
May 9, 2016
123
47
The watch movement arrived and it runs really well. I can not check time because I can not really put a good wind in it until I get the key set. Keys were 14 keys for 10 bucks. I used a small pair of tweezers for watch making to put a small wind in it and the balance wheel just took off. So instead of taking it apart I just oiled it and its on the bench until the Illinois dial I won on eBay arrives. It also fits very nice in the case. I won the auction for the dial I posted above. BTW you guys were correct one leg was cut off. Over all the AWC dial is in very good condition. It could be used with just two legs or if someone wanted to take a rod and solder it to the dial. I would leave it as is and just do two legs.
Appa69
Apr 3, 2022
414
318
44
I agree that two feet is probably enough. The dial does look to be in good condition and, as other have mentioned, is worth a fair amount on its own. Nice watch!
183,938
1,606,552
55,954
Kerogen
3,190
Watch case by Kent
Top Bottom
